Unable to add ip address to live mobile v2.3.1 [fixed]
Posted: 09 June 2013, 00:05
I just upgraded ShowXpress to 6.333 and was trying to upgrade Live Mobile from version 2.0 to 2.3.1 on an Insignia Tablet running Android version 4.0.3. I have read the forums about the Preferences button placement moving to the menu button, but unfortunately I cannot get it to work and I don't have a physical menu button as this is a tablet. For instance if I click the Options button which I believe is the button with 3 dots arranged vertically, I get an option called Settings, if I try to click Settings the text just goes away and I never have the option to enter the IP Address, Port and Password. The Settings option is displayed directly over the Connect To Live button.
I also have the Live Mobile app version 2.0 installed on the same tablet and I am able to connect via that as the Preferences button is above the Connect To Live button, so it's not a firewall setting or anything else, it's an issue specifically between the Live Mobile app and my tablet (Which again works with Live Mobile 2.0). Another interesting item was when I tried to install the Live Mobile app via the Google Play store it said the application was not compatible with my device, so I downloaded the file directly from the link in the forum and installed it that way.
How can I get the IP address into the Live Mobile app version 2.3.1 on my Insignia tablet running Android version 4.0.3?
Thank you!
Tim
Thank you!
Tim
