[MacOS] crtl + click does not work with master fader [fixed]
joedigitaltv
Post by joedigitaltv »
i am on a mac using xpress vers 6.33
my master fader controls nothing no matter if in the 4 master fader or 1 master fader mode.
when using Live the fades do nothing to the output... at least in 3d viewer
any ideas?
my goal is to possibly use the 4 master fader mode to use for fading a whole board of scene buttons if possible
tks
tom
Re: master fader issues
Right click over the master fader, and select "Edit", in order to specify the related channels.
joedigitaltv
that is the issue... i cannot get right click to work on any of the master faders in either mode 1 or 4.
i can right click on any other thing but not on the faders for some reason.
tks
Ok noted. Not easy for us to fix this problem, since we are not able to reproduce it.
Just for info, please tell us your OS version.
Re: [MacOS] master fader issues
We found a problem with crtl + click.
Fixed here: http://download.thelightingcontroller.c ... fix_files/
Please install the new program "Live", in forder "Live" of your software, and let us know if fixed now.
joedigitaltv
That did it. tks.
joedigitaltv
Re: [MacOS] crtl + click does not work with master fader [fixed]
changed computers and this is not working any longer... any ideas?
Did you update "Live" with the one in the "fix files" ?
joedigitaltv
i tried replacing live in the folder with the new file as before but did not work this time for some reason.
tom
Return to “General”
