Movinghead slow in playback
create lighting scenes
MickeyMick
Post by MickeyMick »
Movinghead is slow in playback but not slow when ik manually click the steps.
I want to create a scene with the heads shooting a beam and then move (blackout) to another position and then shoot again
My head is a showtec led 50.
Re: Movinghead slow in playback
For the fastest movement, the transition mode (button below the vertical fader) must be set to "snap" mode.
For "blackout move", you can set channel 12 to "blackout during Pan/Tilt movement" (dmx level 18).
MickeyMick
Is there a trick to setup up the head (in positon) before the shutter opens?
I know you can do it with programming but is there something so the head knows where his posiotin is gotta be?
i want to shoot beams one by one.
head 1
head 2
head 1
head 2
etc.
MickeyMick
Are there coming new curves for the generator in the future?
MickeyMick
Tried it today, but still slow!.
In the software, we just propose a few samples of curves.
However, it is open. You can create/open/save any curve you want, in any lightshow.
MickeyMick
support wrote:In the software, we just propose a few samples of curves.
Good answer, but not the answer i wanted to hear.
Are you guys making new curves or a share your curve topic ;)
Another problem. When i put my heads in 180 degree mode. I cant use the generator, i have to turn my heads 90 degrees. Is there a solution for this?
Return to “Editor”
