[6.332] Problem with active channels in "chase" page [fixed]
Posted: 26 April 2013, 00:00
Hello all!
Since upgrading to the latest version of ShowXpress v6.33 (currently running v6.332 with Live version 2.22.4 - 130408) I have noticed some strange behavior with both Live (and Editor).
In my Live setup I have a macro on a Main page that kicks off a "starter" scene on a random play page of about 20 scenes. The starter scene is just a 2 second scene that does nothing other than start the random play on the page. This worked perfectly in the previous version v6.32 and all of the scenes played perfectly, no problem.
In this version, however, all sorts of strange things are happening. When I click the macro the starter scene runs, then kicks off another random scene, sometimes the next scene works, sometimes it doesn't. When I say "doesn't work" I mean I get nothing, no lights on at all. Strange thing is, if I don't use the macro and I restart the scene manually the scene WORKS perfectly.
On other occasions when i click the macro, starter scene runs, next scene runs, other scenes may run until strange things start to happen like not all of the DMX values seem to be being sent on the active channels on some scenes, i.e. violet lights will only be red with no blue values sent to the lights. Again, when I run the scenes manually they work perfectly!
When I first loaded v6.33 I had a similar problem with Editor, in that sometimes when I tried to playback a scene it, too, seemed like sometimes it would not send all the DMX values on the active channels. I loaded the "fix" versions (the 130408 versions) of both Editor and Live at the time and it seemed to have solved my problem with Editor, but didn't solve the Live issue. So I loaded the full version of v6.332 and Live still does not work (haven't used Editor much since I upgraded to the full version, but, I assume it is still OK)
Does anyone have any idea what could be happening here? Is one of my scenes corrupt? I really don't want to go back to v6.32, but that build seemed much more stable than this latest release which is for all intents and purposes unusable!
Any help would be appreciated!
