Generator Group Order
create lighting scenes
Post by Pink LD »
When I use the Generator, no matter how I select the fixtures Generator treats them in address order. Whatever is my lowest addressed fixture is first and sequentially until my last fixture is my highest addressed. Is their any way to overide the group and set the fixtures in the order I wish? Sure for some effects I can create a curve for a fixture, cut and paste it to the fixture I want and so on and so forth then have multiple scenes Macroed, or merge them when done. But I would rather just set the order of the fixtures myself.
Re: Generator Group Order
It is not possible to change the fixtures order in Generator.
We suggest you to make a dmx outputs patch.
Post by Pink LD »
There are other ways I can do it, and I have. But it struck me the last time I was doing it that it would be easier if I could change the order of the fixtures somehow. Thanks.
spirosaslanis
Post by spirosaslanis »
i have the same problem with the fixtures order ... at the future if you can make possible a order choice ..
sorry for my english
Understood and noted.
spirosaslanis
thank you
Return to “Editor”
