Chauvet 4 Bar
Posted: 28 June 2012, 10:17
by JohnRichards
For Support or Chauvet
I have a client that I am doing a demo for and he would like to use Chauvet SlimPars or 4 Bar Flexes, and it is noted that once the 4 Bar fixture is imported from Chauvets profiles, in 3D View it does not display correctly. When the 2nd channel (dimmer) is activated with any of the rgb colours, the 3d view is in strobe mode. This was solved by changing channel 3 to a "shutter" instead. My question, is it only in 3D view that we will see this error, or will it also have to be changed when the unit is connected.
Re: Chauvet 4 Bar
Posted: 28 June 2012, 21:35
This is not an error.
The channel name just must be called "shutter", in order 3DView can show strobe effect or "open" effect.
Re: Chauvet 4 Bar
Posted: 29 June 2012, 16:35
by JohnRichards
Thank you
