Intimadator 150 default position question
Razorback
Post by Razorback »
I am using 4 intimidator 150s along with a few other lights to run live. I have the left 2 of them set normal and the right 2 set to reverse pan.
After I write a scene and put it into the timeline, when the scene starts the 2 right (reverse) lights have to spin to "catch up" (for the first second or so) position wise with the 2 lights that are set to "normal" because when the lights are reversed I have to turn both fixtures to face backwards. I have gotten into the fixture settings hidden settings and tried to change the default tilt/pan values but they didn't seem to change at all when I adjusted the values(maybe i am missing something). I would rather avoid setting the reverse fixtures back to normal if possible so I don't have to program the L and R lights separately in order to mirror each other. Is there anything I can do to avoid this happening?
posting.php?mode=post&f=9
Here is a link to a video to show you what I am talking about. Notice the Right 2 Intimidators.
http://www.youtube.com/watch?feature=pl ... vTX99wqzOc
I am running:
The latest ShowXpress
Xpress512 interface
Any help/tips would be appreciated
Thanks!
Re: Intimadator 150 default position question
Could you please send the easiest possible lightshow (with only 2 fixtures) which shows that problem ?
Razorback
Post by Razorback »
Scene sent.
The "reverse" infos are missing.
We need the complete lightshow.
Razorback
Post by Razorback »
I am not exactly sure what files to send. (sorry)
Do I need to just send you the "default" folder?
Razorback
Post by Razorback »
I read all of that before posting. I am not sure what you meant by "send complete light show". Do I sent the entire "lighting controller" file? Or the "default" file? I wasn't sure because I have a bunch of scenes and timelines in those folders that have nothing to do with the lights I am having a problem with.
tomrbland
Post by tomrbland »
Right click control board and select "export light show" select the light show that you want to export and the destination folder. Does that make sense?
Razorback
Post by Razorback »
Makes total sense. I have been saving all of my scenes/timelines etc. in the default folder. I'll get it all to you a bit later today. I havent created a "new lightshow" since using the software. Thats why i was confused. Thanks for your patience... :-) I'm a noob
Razorback
Post by Razorback »
sent.
