American DJ - Quick Scan Sys
Re: American DJ - Quick Scan Sys
The manual says the fixture has one channel, but we were not able to find any details about the functions !
So we can not do the personality file.
We need the complete manual with all dmx functions.
kphn
Post by kphn »
I talked to the dealer and he said the manual i send you is the only one.
Done.
kphn
Post by kphn »
I can't do anything with the light. What can i use the light for if it can't pan, tilt or turn off
The manual says the light has only one channel for speed.
kphn
Post by kphn »
Okay.
kphn
Post by kphn »
Does this mean that the lights are controlled by the music but I can control the speed on them?
It sounds like.
In order to know more about this light, we suggest you to ask the manufacturer (we are only support of the TheLightingController).
JohnRichards
Post by JohnRichards »
In reading the manual that you sent to support, it appears that the system operates mainly as a stand-alone unit and is controlled by the sound it receives. It also states that to use in dmx mode, you must turn the volume control off. I would then presume that the fader for the controlling dmx unit would then change the speeds of the mirror. You could monitor the unit yourself and see what it does at each level of the fader (0-255)
