Error "Can not find '../Setup/Setup.exe'" (Windows only)
The recent internet upgrades of Windows 7 64bits has increased so much the level of protection, that now the OS (Operating System) does not allow to run files having a specific name. That is why, if the OS UAC (User Account Control*) slider is not set to the minimum value, you will see an error message when starting "Setup" from ControlBoard.
Microsoft fixes the rules, so even if this makes no sence, we have no choice to rename our application "Setup" with the new name "SetFix". This change is available from software version 6.30beta2 and above.
In conclusion, two solutions:
- you keep your current software version, and you set the OS level protection slider to the minimum value
- you install software 6.30beta2 or above
*User Account Control: http://windows.microsoft.com/en-US/wind ... nt-control
Return to “Setup”
