BPM sync with DJ software
Re: BPM sync with DJ software
In my experience it is best to set Win7 to "work" network to communicate correctly with WinXP.
Thanks, that is what I thought. Sorry I did not mention that after seeing it was set up the way it was at home, I also tried the other settings (Work). Then I looked into how to set up Advanced options on that firewall. Ran out of time so last min, disabled both firewalls.
At home I opened up the port on the Win 7 machine (set back to Home at this point) and still would not work. So I will try this when I get home. Thanks for the suggestion.
Just a quick note on this plugin, I noticed the when using the latest Fix files on 6.32, there were some lags in step advances using this plug in.
Before (master faders) they were very steady. Now it will go "Red..Green..Blue.............PurpleYellowOrange..Red.."
So if it pauses, it seems to play catch up fast, like it got all the signals. Lags happen pretty often too. Any help you can give would be great. Thanks
