If I am at an event and the music stops because I am making an announcement, this is what I want to happen the lights to stop. Other software on the market will continue with the last BPM measurement which is not desireable.support wrote:Either there is a bug in our code, or the midi clock device is not accurate.it sometimes misses a beat here and there
Could be a blip but still more accurate than the microphone.
If the music is played by the same device which outputs the midi clock, it looks like the problem comes from this device.Interestingly when the music stops so does the BPM meter which is perfect
This is the action you want to happen!
Our code just moves the BPM with the incoming midi clock.The last thing you want is the lights to continue if the music stops playing
So far, midi clock is basically to synchronize the midi instruments. So it is always running, and this is effectively not really good with lights.
Thank you for the work!
