request - better steps sync with Beat [done]
create scenes with steps
djdad
Re: request - better steps sync with Beat [done]
Post by djdad »
I believe the latest should be 9.2.14
Patch is available here.. https://forum.thelightingcontroller.com ... f=85&t=114
daan44444
Post by daan44444 »
I have found and installed the newest patch.
I did find a flaw in this feature though. The functionality of the "Run scene from 1st step" is working properly, thanks for this amazing feature! But, when the scene duration is shorter than the time in between beats, the scene will continue playing, while I want it to pause on the last step. When I enable "Pause on last step" for this button, the scene still continues playing. Would it be possible to fix this bug?
thorehl
Post by thorehl »
Do you have Speed properties set to Beat for that button?
Thore
Controller: 2x Akai APC mini
my DIY light mixer
daan44444
Post by daan44444 »
Speed properties are set to BPM. But with beat I get the same result as stated in my previous comments
daan44444
Post by daan44444 »
Hi all,
I have found the bug behind my problem.
If all channels are set to snap in all steps, this functionality works perfectly. If any channel in any step is set to fade, even though the rest is set to snap, the functionality doesn't work. Ik does not pause at the end, but in fact, continue running.
In short, all the channels and steps HAVE to be set to snap and I can't use fade in the entire scene. Would it be possible to fix this issue?
There is effectively a problem, which is indeed not easy to flush out.
First quick analyse tells us the problem happen when, in the last step, the changing channel is set to "fade" mode.
Thank you for this feedback.
We will come back to you asap regarding this.
Fixed in the fix file (V9.17).
thorehl
Post by thorehl »
Nice work.
Thore
my DIY light mixer
daan44444
Post by daan44444 »
Super quick! Thank you! Now, I can't wait for v10 to come out. Any update on the progress?
Return to “Editor - Steps”
