problem when using 2 interfaces together [fixed]
				kcampb8965
Re: Emergency
As I have indicated, I can run 1 Universe at a time on either light string and each will work independently.  I ran an entire show with my moving heads on Sunday with no problem.  Then I ran a simple par show (from the other string) and it worked with no issue.  It's only when I run two universes simultaneously that I have a problem. And while trouble shooting, I did try to hook up just 2 lights, but as with a full rig, I can operate each light independently.  It's only when I try 2 Universes at once that I have a problem.  Also, I ran each interface separately with no issue and replaced both cables.
				kcampb8965
Re: Emergency
A special Thanks to Earl Harvey.  I thought he was asking if I was plugged into a powered USB port as if that would cause a problem.  I bought a powered USB port today and it appears my problem is solved.  It worked this after noon in a trial.  I go live with it Monday.  Here's hoping this has done the trick.
