Page 2 of 3
Re: Audio stops when play timeline
Posted: 04 August 2015, 12:09
by medbi
Could you please provide me with an email address so I can sent in the show. If 32 gb is to big for your email... could you give me a fiscal adress (adres in real world), we can sent it to urgenlty.
Thank you,
Ive
WAVEFROM: Ok, I will try that. Even though on Mac it does not seems to display wavefrom but have deselected it just in case.
Posted: 04 August 2015, 15:57
by medbi
I have scaled down the show to 10gb more or less... do you have an email I can sent it to?
WAVEFORMS: I can not see them on mac but have turned them of just in case (they were selected). I will try this since someone suggested me to do so. Thank you, will see what happnes...
Posted: 05 August 2015, 08:44
Our software does not play & decode the media file by itself ; it just asks the OS to play it.
So we suspect a problem with QuickTime and the present Codecs in your Mac computer.
To check that, please try to run all your files straight with QuickTime, and tell us if you still see the problem.
Posted: 05 August 2015, 08:57
by Niffo
Please, can you also tell us if the TimeLine stops when the audio stops.
If not, you could try with different audio encoding (IE. WAV if your files are MP3)
Regards.
Posted: 05 August 2015, 12:04
by medbi
All files are wav format. The problem is the even if I run them all in quicktime... I dont have a definitive answer... since the problems are not consistant. Some time they happen, another day it works fine...
Posted: 05 August 2015, 12:06
by Niffo
Please, can you tell us if the TimeLine stops when the audio stops.
Posted: 05 August 2015, 20:21
@ medbi
The reason we are looking eagerly for the answer of this question is it will tell us more about where to investigate.
Posted: 12 August 2015, 15:45
by medbi
From all the infromation I got, it looks like the timeline keeps running... lights workand keep on working, just sounds disapears...
Posted: 12 August 2015, 15:48
by medbi
Is it possible that leaving the computer onattended could cause this problem? I thought this was the problem at first so have deactivated sleep timer, screensaver and everything else like that. Yet so far the problem seems to continue...
The shows were we are touching the computer because of pauzes in timeline and to do other stuff... it does not seem to happen... at least not that I have been informned of. Is this possible? So far it is just speculation...
Posted: 25 August 2015, 08:12
by medbi
I have converted all .wav files to .mov files... that seems to be working... but to little data to know 100 procent for sure...
