Re: Advanced Live control
Posted: 01 December 2012, 08:05
I do mainly live theatre work, dance and ballet shows etc... and the idea of this advanced control would be mainly used during the rehearsal stages of the shows. Most of the changes would be the different settings for a mattinee or evening show where the colours are affected the most.
As we are talking about the adjustment of dmx values, I would like to see a fader which is in the central position "0%" and scales "+10 to +100%" above and "-10 to -100%" below. The software should allow for more than 1 fader to be configured for the users groupings, (ie - 1-Selected dimmers for White, 2-Selected dimmers or RGBAW for Colours, 3-Selected channels for All Fade and so on).
Ideally this should be an additional window that could be selected as "Load with Live" or as a separate item in Control Board.
The main idea is to be able to do a quick adjustment as soon as possible and not change any programmed scenes.
If a separate window is not possible, there is space on the main Live page, if the buttons on the right of the screen were reduced in size and moved around a bit.
