Spotlight positions change on some scenes
Postby boogiemarshall » 21 March 2021, 14:34
I have created a step scene with my 5 movers trained on one band member. It looks fine until I load this scene into the timeline and then all of the positions are wrong. When I click on that scene and select "edit", the scene looks fine. I'm on 9.2.23 using a 2020 MacBook Air (with Intel chips) running macOS Catalina 10.15.7. I am using a Rack-1024
boogiemarshall
Re: Spotlight positions change on some scenes
Postby Pauluzzz » 23 March 2021, 14:03
Did you try to do the same by using a generator file? This has the additional advantage that you can easily offset the spotlights with every new stage build. Alternatively you could consider using palletes as well.
Pauluzzz
Postby boogiemarshall » 24 March 2021, 18:20
Thanks, I’ll give that a try.
Right now I am just programming and checking my work in the 3D viewer. I’ll get everything hooked up and take it for a test drive this weekend. My band doesn’t use automation or a click, and we run everything from the stage, so that presents many challenges. Fingers crossed. Once again, thank you for the response!
boogiemarshall
Return to Live - TimeLine
