OS2L not working on VDJ2020 [fixed]
live control with Virtual DJ
Postby GPC » 11 November 2019, 16:52
I am trying to use os2l direct with Virtual DJ 2020 and cannot make it work. I was previously using it via Apple Bonjour which did.
And set up help or information about this would be great.
Many thanks
Gary
GPC
Re: OS2L not working on VDJ2020
Postby Bob_be » 11 November 2019, 21:02
In VDJ, do you have the os2l option set to "Yes" and the os2lDirectIp blank?
In Showxpress, have Virtual DJ enabled, with the port 7350?
Bob_be
Postby GPC » 12 November 2019, 00:23
Thank you for your reply.
Yes I have tried the VirtualDJ setting you suggest.
But in the Showxpress preferences, if you enable VirtualDJ it tries (and fails) to load Apple Bonjour when the software restarts. And still doesn't receive the beats from VirtualDJ.
GPC
Postby Bob_be » 12 November 2019, 16:54
maybe try reinstalling Bonjour???
Have you tried Pads (in VDJ) Buttons? Does Showxpress receive the button press from VDJ?
Bob_be
Postby GPC » 12 November 2019, 21:30
It's supposed to work without Bonjour now.
GPC
Postby Bob_be » 12 November 2019, 23:46
Sorry, it's been a while since I upgraded. I couldn't remember if it used it or not.
Have you tried the Pads? Does Showxpress respond?
Bob_be
Postby support » 13 November 2019, 08:00
"Bonjour" must be installed (https://youtu.be/pC4bA3Ioy-g?t=10).
Postby GPC » 13 November 2019, 11:27
Thank you for the video link.
I was under the impression we could now link VirtualDJ directly with OS2L and not have to use Bonjour. Is this coming to ShowXpress?
GPC
Postby support » 13 November 2019, 17:10
So far, OSL2 needs "Bonjour".
Postby GPC » 14 November 2019, 11:26
Ok, thank you for the clarification.
Hopefully, the need for Bonjour will be addressed in a feature update.
GPC
Return to Virtual DJ
Users browsing this forum: No registered users and 26 guests
