3x Net 512 interface with Artnet [fixed]
Ethernet to dmx - web server - 9 buttons - calendar
Re: 3x Net 512 interface with Artnet
Postby autogedrocht » 01 May 2019, 14:13
support wrote:Yes, please press "Autodetect interfaces" and tell us how many interfaces are found.
There are always minimal 2 interfaces found.
When i try only 192.168.1.35 it says 2 interfaces, same as for .45 and .55 individually.
When i try .35 and .45 at the same time, 4 interfaces are found.
When i try them all at the same time, 6 interfaces are found.
autogedrocht
Postby autogedrocht » 01 May 2019, 14:32
support wrote:Please tell us also if the dmx output is running with all interfaces (sending value = 0 for all dmx channels).
When 6 interfaces are found and when in the hardware tab also 6 interfaces are filled in with an ip adress. -> No DMX is send to the output
When 6 interfaces are found and in the hardware tab i only fill in 3 interfaces ip adresses (other ones i fill ip .0 in). ->DMX is send to the output
see images
autogedrocht
Postby support » 01 May 2019, 18:53
Even with one interface connected, the software see two interfaces !
In order to know if the problem is exclusively with your Ethernet network, could you please check on another Etnernet network ?
Another question
If you leave only the three first IP's and you delete the three last one, does the setup (software + interfaces) work well ?
Postby autogedrocht » 01 May 2019, 20:01
I shall try that.
Yes, that works good.
Question by me:
When you use only 1 net512 interface, you use the DMX output on 1 universe. How do you use the Artnet. Do you have to make another universe for only artnet?
autogedrocht
Postby support » 01 May 2019, 21:27
So please do like this, and we will wait for the test with another Ethernet network.
Please follow this for Artnet: https://forum.thelightingcontroller.com/viewt ... =81&t=3741
Postby autogedrocht » 02 May 2019, 08:34
support wrote:Even with one interface connected, the software see two interfaces !
In my Business network it sees only 1 interface. (1 x net512) Like it the way it should be.
So, it looks like it is something in the router?
autogedrocht
Postby support » 02 May 2019, 10:17
Yes, it looks like.
Postby autogedrocht » 02 May 2019, 11:26
So, any hints or tips?
autogedrocht
Postby support » 02 May 2019, 11:33
We think the problem come from the router.
It may be better to change it (?)
In another hand, if it works like this, you may also leave the setup as it is.
Re: 3x Net 512 interface with Artnet [fixed]
Postby autogedrocht » 02 May 2019, 11:38
Ok
Well it works.
The most annoying part is that when you assign a interface to a universe, you see 6 interfaces. So how do you need which to pick?
It would be handy in every interface would get a number, maybe you can implement that in the future.
Or should i disable EnabelChnage DMX universes mapping?
autogedrocht
PreviousNext
Return to Net512
