request - home Position
muscanto
Post by muscanto »
The request is to have a screen section inside each fixture when you edit the fixture to default the Pan and Tilt value to a value other then 0 when the program starts up. When no scenes are enabled, the fixture's Pan and Tilt will go to those values as a default. Other programs refer to this feature as a "home position."
Re: Home Position
Understood.
But not easy to figure out because there are several tabs (Steps, Generator, ...).
Do you have any idea of where to put that function ?
muscanto
Re: request - home Position
Post by muscanto »
Editor Tab > Fixtures Tab > Rick click on one or multiple fixtures > "Home Position" option.
The Option would be grayed out if fixture does not at least have a pan and tilt channel configured in it's channel properties. (upan and utilt not required)
A window pops up that includes the pan/tilt grid editor on one side and four faders with fields to enter manual DMX value 0-255 like the steps editor on the other side. (pan, upan, tilt, utilt)
If any of these channels are not enabled for that fixture, they either would either not show or would be grayed out.
Thank you!
Do you mean that, when the pan/tilt channels are not activated in Steps/Generator/Live, they will be at home position ?
muscanto
Post by muscanto »
Yes - Exactly!
Thank you for your clear explanations.
Added in the ToDo list.
thorehl
Post by thorehl »
+1 Well, most of us have this as a step scene, but yes. Saves me space on "Setup Page"
Thore
Controller: 2x Akai APC mini
my DIY light mixer
It looks effectively redondant to add a new "home position" setting window, while it can be built easily in tab "Steps", and then simply switched on or off in the tab "Live".
If it is not in the setup page, we will need a new button to active it or not.
Gilles
Post by Gilles »
Moi j'ai effectivement créé un une scène dans "steps" que j'ai appelé "home", et je l'ai mise dans live avec un démarrage auto, comme cela même si je n'ai aucune scène enclanchée, mes automatiques sont toujours en position.
muscanto
Post by muscanto »
Gilles wrote:Moi j'ai effectivement créé un une scène dans "steps" que j'ai appelé "home", et je l'ai mise dans live avec un démarrage auto, comme cela même si je n'ai aucune scène enclanchée, mes automatiques sont toujours en position.
C'est génial. Ce que nous demandons, c’est une fonctionnalité qui évite d’utiliser de l’espace sur votre écran et un bouton dédié à une fonction intégrée à la plupart des autres applications de contrôle de l’éclairage.
Return to “Live - Buttons”
