AmpdEntmt wrote:@Bonifacedj I just had a look at your screenshots and everything is done correctly.
Thanks for checking out.
AmpdEntmt wrote:This seems like a software issue to me, because midipipe is not distinguishing between the two seperate controllers with the same name.
Yep, that's the issue. So the tittle of this topic isn't totally correct, they work at the same time, but not as two separate controllers. Kinda like mirrored display's now.
which isn't a surprise, because as you noticed too, midipipe is not distinguishing between the two seperate controllers with the same name.
So using 16 devices as you wrote earlier in your guide
viewtopic.php?f=76&t=4169 might be possible, but only on the condition they are all unique types. 16 mirrored controllers isn't useful.
AmpdEntmt wrote:If you can figure out how to change one of the device's names, I believe your problem will be solved.
I am also curious to see how @jjurisch merged his/her midi signals with the same names. A message to him/her may be a good idea.
Yes, changing the device's names seems to be possible, @jjurisch must have found a way to do that.
i'll send him a PM.
