Hey guys!
I recently purchased a APC Mini to go alongside my launchpad, and had read previously about using software so two controllers can be used, but now I am attempting to do so its like a minefield!
Can anyone supply a step by step guide/screenshots on how to do so? I'm pulling my hair out with this and would greatly appreciate the help!
Cheers,
Chris
Using MIDI-OX! Step by step guide?
Re: Using MIDI-OX! Step by step guide?
Thought i would post some screenshots, might help saving some time!
This is the setup i have within MIDI-OX, using loopMIDI to create the "IN" and "OUT" port:
Then the routing of the controllers, LAUNCHPAD & USB AUDIO DEVICE(APC MINI) to the output made via loopMIDI:
And finally, as i understand it this is how i should have it set in Sweetlight:
A few things that i have noticed while fumbling around all of this, that could lead to a resolution aswell:
When pushing any button on either controller they will light up on "1" for the input port, is this correct?
Is it still possible while doing all of this still to get the feedback from the controllers, i.e the buttons light up?
Hopefully someone can help me on this as i have a gig at the end of the month ha!
Cheers,
Chris
Cheers,
Chris
Earl Harvey
This may help... here's mine...
You'll need to create some Midi Transform maps on Midi OX that will transpose the midi channel for each controllers in and out...
I suggest you dont use channel 1 since the controllers are transmitting on Ch1 already....
1 map per input, another one for each output...
How on earth do i create midi transform maps and how do i change the input?Earl Harvey wrote:This may help... here's mine...
You'll need to create some Midi Transform maps on Midi OX that will transpose the midi channel for each controllers in and out...![]()
Can you tell i have no idea what i am doing ha? This is so frustrating ha!
Earl Harvey
Translation Map
- Translation map.png (94.48 KiB) Viewed 30767 times
Earl Harvey
Check connection properties box...
add correct map for controller...
- Conection properties.png (98.23 KiB) Viewed 30766 times
Do I do this to all the devices then? So id have one that says "2" and the other that says "3"?Earl Harvey wrote:Translation Map
How do i then apply this to each device?
Earl Harvey
It's a nail bitter... grab some tissue and some shotgun shells!
make sure you launch loop Midi first then MIDI OX before SX
Ha yes!Earl Harvey wrote:It's a nail bitter... grab some tissue and some shotgun shells!
If there is anyway we can go through this privately? Skype? Facebook? Id would appreciate it big time!
Earl Harvey
Facebook is fine... Earl Harvey
