MIDI output support in V7
Re: MIDI output support in V7
Postby toddlarboy » 27 May 2014, 17:49
can't wait to try this. Now I can use even better MIDI controllers since I can take advantage of more features. Thank you!
toddlarboy
Postby LightWorx » 30 May 2014, 00:55
Launchpad illuminated with less than 5 minutes setup time. Thank You Support!
LightWorx
Postby chibbert » 11 June 2014, 00:05
Can the new speed sliders be controlled by MIDI?
chibbert
Postby Niffo » 11 June 2014, 05:02
Yes
Postby chibbert » 11 June 2014, 18:40
Great! How do you control the speed sliders with MIDI?
chibbert
Postby Niffo » 11 June 2014, 19:02
- Enable "Midi In" and choose a device in general Preferences and restart the Software
- Enable and configure "Midi In" in "button trigger" of "Live" button
Postby chibbert » 11 June 2014, 22:25
Right. I understand how to enable MIDI control of a button. Thank you.
But MIDI control of a new speed-slider button does NOT affect the button's speed slider. I want to be able to adjust the speed slider using MIDI.
Currently, a MIDI command just enables/disables the button in ShowXpress. The speed slider is unaffected.
Can you confirm? Thank you!
chibbert
Postby Earl Harvey » 12 June 2014, 00:29
You need to make sure your controller is transmitting a CC (Control Change) from the fader not a Note on/off or other type of message... It's working for me...
Earl Harvey
Postby chibbert » 12 June 2014, 04:03
Ah. Great. Thanks, Earl. I'll check.
chibbert
Postby Earl Harvey » 17 June 2014, 10:01
In Preferences it won't remember the MIDI out device, I have to reselect it then reboot the program...
it seems to be better in the Beta version 7.0.67 though...
Earl Harvey
PreviousNext
Return to Midi
