Everything works except the POI's
live control with Virtual DJ
Postby Btucker » 15 November 2018, 01:08
I am having the same problem (working in Windows 10) And I have verified that I have the proper drivers. EVERYTHING works EXCEPT the POI Editor.
Btucker
Re: Trigger problem with POI's [fixed]
Postby Bob_be » 15 November 2018, 16:22
Do you have capital letters in your button names in Showxpress/Sweet Light/etc.? There is a bug in VDJ that converts capital letters to lower case letters when passing thru to Showxpress...or any other lighting software.
Bob_be
Postby Btucker » 16 November 2018, 00:44
I tried renaming the base scene removing all caps. I have removed all caps from the command argument in the POI editor. - NOTHING.
To be clear. EVERYTHING else works including the Hot Cue buttons reassigned as DMX works perfectly. It simply will not trigger in the POI.
Btucker
Postby Bob_be » 16 November 2018, 03:05
Can you post a picture(s) of your POI Editor.
Bob_be
Return to Virtual DJ
