OS2L button names must be in lower case
Posted: 08 October 2018, 06:45
I just loaded v9 today, and I'm testing out the os2l commands in VDJ.
I've noticed that the buttons in Live must be in lowercase to work. If I have a button named "Blue", the os2l_button 'Blue' command will not activate it, but if I rename the button to be "blue" and then change the command to os2l_button 'blue' it does work.
Is there a way to fix this, or will I have to go rename all my buttons to lowercase that have upper case?
Testing using Windows 10 (1803), VirtualDJ v8.3 b4592 32 and 64 bit versions, ShowXpress 64bit v9.1.0 - 180912
