Controlling fader button with Midi rotary button
Postby autogedrocht » 22 December 2015, 22:03
Hi!
I have a Elation Midicon Pro for controlling Sweetlight, but i can't get rotary buttons work properly.
In "Live" I have created a fader button. When I (midi) trigger this button with a fader on the Elation it works great. When I move the fader on the controller I see the percentage changing on screen.
But when I use a rotary button on the Elation as midi trigger, it only turns the button on or off.
To solve that, i used the Elation midimapper and adjusted the rotary button to send a controller midi message instead of a note on-off. (see attachment), but that doenst work. The button now only goes on, and stays on using the rotary.
So, whats wrong?
When I select the rotary as trigger, it automatically shows a "Controller", same as with the faders. So that seems ok..
The same happens with using a preset fader, i have the same problem.
Any idea?
autogedrocht
Re: Controlling fader button with Midi rotary button
Postby support » 23 December 2015, 22:07
Like it does with the midi fader, the position of the wheel from min to max has to set "data byte #2" from 0 to 127.
Postby autogedrocht » 27 December 2015, 19:12
Do i have to do that in the Elation software or in Sweetlight?
I dont understand how to send the data byte 2.
In the midimapper i only have options shown in the picture of my first post of this topic.
autogedrocht
Postby support » 28 December 2015, 10:08
In your midi device, the wheel has to send a similar midi message than the fader does.
Return to Midi
Users browsing this forum: No registered users and 46 guests
