After applying Fix file - Wont start up
Postby Cablecr69 » 02 April 2024, 22:04
I am running 9.3.9. When I download the latest fix file and apply the software no longer will open.
Im apply the library file and the English ini file.
I will be trying VII on my M1 soon but still want a stable one on my other Mac.
Thanks,
Chris
Cablecr69
Re: After applying Fix file - Wont start up
Postby support » 03 April 2024, 07:50
Please post a link to download a zip of your lightshow.
We will check that.
Postby Cablecr69 » 16 April 2024, 15:17
Hello Support,
https://drive.google.com/drive/folders/ ... sp=sharing
Here is a link to the show file with music and a zipped version without.
Thanks,
Chris
Cablecr69
Postby support » 18 April 2024, 10:56
The ZIP file contains our software. This is not what we need. We need the lightshow (https://forum.thelightingcontroller.com/viewt ... ?f=3&t=168).
We have your WAV files.
Postby Cablecr69 » 24 April 2024, 21:43
I have exported the lightshow and added it to the google drive under folder DSUK.
This is from the version that is working as when I apply the fix...it will not load.
Cablecr69
Postby support » 26 April 2024, 08:11
No problem with your lightshow and the latest version of our software here.
https://ibb.co/Ms3fqYV
Could you please send the file "param.ini" which is one level above your lightshow folder.
(the path is ".../home_directory/TheLightingController/param.ini")
Postby Cablecr69 » 06 May 2024, 14:00
Here is the file.
param.ini
(297 Bytes) Downloaded 4 times
Cablecr69
Postby support » 06 May 2024, 14:31
We do not see any problem in this file, either.
Could you please try with the latest fix for V9.3.14 (https://forum.thelightingcontroller.com ... =85&t=3438) and let us know ?
Postby Cablecr69 » 06 May 2024, 21:53
Same problem.
This is apple crash report.
Process: TheLightingController [3730]
Path: /Users/USER/Desktop/*/TheLightingController.app/Contents/MacOS/TheLightingController
Identifier: TheLightingController
Version: 0.1
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: TheLightingController [3730]
User ID: 502
Date/Time: 2024-05-06 22:51:04.493 +0100
OS Version: Mac OS X 10.13.6 (17G14042)
Report Version: 12
Anonymous UUID: 0F1464C6-BA5E-8201-B2FE-0C6CF50C4532
Sleep/Wake UUID: 4094B723-BCF9-4D5E-8B31-DDD844D1B2F1
Time Awake Since Boot: 7200 seconds
Time Since Wake: 3700 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x4] Symbol missing
Dyld Error Message:
Symbol not found: ____chkstk_darwin
Referenced from: /Users/USER/Desktop/*/TheLightingController.app/Contents/MacOS/TheLightingController
Expected in: /usr/lib/libSystem.B.dylib
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 dyld 0x000000010d28d256 __abort_with_payload + 10
1 dyld 0x000000010d28cbc8 abort_with_payload_wrapper_internal + 89
2 dyld 0x000000010d28cbf5 abort_with_payload + 9
3 dyld 0x000000010d260482 dyld::halt(char const*) + 354
4 dyld 0x000000010d2605a9 dyld::fastBindLazySymbol(ImageLoader**, unsigned long) + 170
5 libdyld.dylib 0x00007fff56331292 dyld_stub_binder + 282
6 ??? 0x0000000104ecac30 0 + 4377586736
7 libdyld.dylib 0x00007fff56331015 start + 1
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000002000209 rbx: 0x0000000000000004 rcx: 0x00007ffeeb00f9b8 rdx: 0x00007ffeeb00fe30
rdi: 0x0000000000000006 rsi: 0x0000000000000004 rbp: 0x00007ffeeb00fa10 rsp: 0x00007ffeeb00f9b8
r8: 0x00007ffeeb00fa30 r9: 0x0000000000000000 r10: 0x00000000000000b0 r11: 0x0000000000000246
r12: 0x00000000000000b0 r13: 0x00007ffeeb00fe30 r14: 0x0000000000000006 r15: 0x0000000000000000
rip: 0x000000010d28d256 rfl: 0x0000000000000246 cr2: 0x000000010d2ddfe0
Logical CPU: 0
Error Code: 0x02000209
Trap Number: 133
Binary Images:
0x104bef000 - 0x104eb2ff7 +TheLightingController (0.1) <81E0D438-83C0-389D-9FD7-94215E83B8C3> /Users/USER/Desktop/*/TheLightingController.app/Contents/MacOS/TheLightingController
0x10d25c000 - 0x10d2a6adf dyld (551.5) <CB9BFB56-4511-36F1-A546-891FF770C01C> /usr/lib/dyld
0x7fff2a3cf000 - 0x7fff2a5afff3 com.apple.avfoundation (2.0 - 1536.36) <AB868021-AB26-3198-897D-087EF3B360EA> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff2a5b0000 - 0x7fff2a669fff com.apple.audio.AVFAudio (1.0 - ???) <716306C4-A0EA-3D81-8F33-943153538C47> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff2a66b000 - 0x7fff2a76efff com.apple.AVKit (1.1 - 440.10) <F684B2B0-4C97-3AD2-AFFE-B6561175621C> /System/Library/Frameworks/AVKit.framework/Versions/A/AVKit
0x7fff2a76f000 - 0x7fff2a76ffff com.apple.Accelerate (1.11 - Accelerate 1.11) <8632A9C5-19EA-3FD7-A44D-80765CC9C540> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff2a787000 - 0x7fff2ac85fc3 com.apple.vImage (8.1 - ???) <A243A7EF-0C8E-3A9A-AA38-44AFD7507F00> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff2ac86000 - 0x7fff2ade0fe3 libBLAS.dylib (1211.50.2) <62C659EB-3E32-3B5F-83BF-79F5DF30D5CE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff2ade1000 - 0x7fff2ae0ffef libBNNS.dylib (38.1) <7BAEFDCA-3227-3E07-80D8-59B6370B89C6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff2ae10000 - 0x7fff2b1cfff7 libLAPACK.dylib (1211.50.2) <40ADBA5F-8B2D-30AC-A7AD-7B17C37EE52D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff2b1d0000 - 0x7fff2b1e5ff7 libLinearAlgebra.dylib (1211.50.2) <E8E0B7FD-A0B7-31E5-AF01-81781F71EBBE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff2b1e6000 - 0x7fff2b1ebff3 libQuadrature.dylib (3) <E936BDAF-8492-34D9-8C5C-AFBFCDAD8318> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff2b1ec000 - 0x7fff2b26cfff libSparse.dylib (79.50.2) <0DC25CDD-F8C1-3D6E-B472-8B060708424F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff2b26d000 - 0x7fff2b280fff libSparseBLAS.dylib (1211.50.2) <722573CC-31CC-34B2-9032-E4F652A9CCFE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff2b281000 - 0x7fff2b42efc3 libvDSP.dylib (622.50.5) <40690941-CF89-3F90-A0AC-A4D200744A5D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff2b42f000 - 0x7fff2b4e0fff libvMisc.dylib (622.50.5) <BA2532DF-2D68-3DD0-9B59-D434BF702AA4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff2b4e1000 - 0x7fff2b4e1fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <54FF3B43-E66C-3F36-B34B-A2B3B0A36502> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff2b7d5000 - 0x7fff2c633fff com.apple.AppKit (6.9 - 1561.61.100) <4E6EA3FA-8C2C-3B21-BFF9-6F8C458B7BE1> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff2c685000 - 0x7fff2c685fff com.apple.ApplicationServices (48 - 50) <2B5B76E7-0AB2-31F9-BE58-B963BF1EC2E8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff2c686000 - 0x7fff2c6ecfff com.apple.ApplicationServices.ATS (377 - 445.5) <60176327-F757-308E-B61A-D43394E87CC5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff2c785000 - 0x7fff2c8a7ff7 libFontParser.dylib (222.1.9) <FFF2AC1A-D4D2-3AD3-BFF2-F3649ECB02AC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff2c8a8000 - 0x7fff2c8f3ff7 libFontRegistry.dylib (221.6) <30C6D1DE-C0E3-3447-A0EF-829443D95F0E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff2ca35000 - 0x7fff2ca39ff3 com.apple.ColorSyncLegacy (4.13.0 - 1) <04764FB2-22D8-36F0-9647-2D21562E28D5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff2cad9000 - 0x7fff2cb2bffb com.apple.HIServices (1.22 - 625) <3C059A55-1409-373E-BF0B-C3299AFABDCF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff2cb2c000 - 0x7fff2cb3afff com.apple.LangAnalysis (1.7.0 - 1.7.0) <8BB267F4-D5AA-3D35-8269-1A3CEA054ACD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff2cb3b000 - 0x7fff2cb87fff com.apple.print.framework.PrintCore (13.4 - 503.2) <2EA98448-9D6A-3912-9933-F7703CB01B6E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff2cb88000 - 0x7fff2cbc2fff com.apple.QD (3.12 - 404.2) <525E9518-DFF3-3D8D-BD48-E0D63EEDBD16> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff2cbc3000 - 0x7fff2cbcffff com.apple.speech.synthesis.framework (7.8.1 - 7.8.1) <CD09019C-569B-3A56-B84C-26F2A6223455> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff2cbd0000 - 0x7fff2ce5eff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <C7BE1645-BE23-3427-8650-1CEFDAF86710> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff2ce60000 - 0x7fff2ce60fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <294802B9-E24D-34EB-973F-6D2B8E2E86CB> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff2d183000 - 0x7fff2d520fff com.apple.CFNetwork (902.6 - 902.6) <46168F79-CCFA-349A-8508-B8CBCE27D440> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff2d535000 - 0x7fff2d535fff com.apple.Carbon (158 - 158) <F8B370D9-2103-3276-821D-ACC756167F86> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff2d536000 - 0x7fff2d539ffb com.apple.CommonPanels (1.2.6 - 98) <075486A5-8E39-3F72-BED7-752517379C55> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff2d53a000 - 0x7fff2d83ffff com.apple.HIToolbox (2.1.1 - 911.10) <8D2EBE85-9AF0-38BC-ACD3-1ED978643907> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff2d840000 - 0x7fff2d843ffb com.apple.help (1.3.8 - 66) <7F210C1C-D7D3-3C97-A2E4-D3CC35F91807> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff2d844000 - 0x7fff2d849fff com.apple.ImageCapture (9.0 - 9.0) <3993E094-AB86-3B22-BC18-4550F23854FF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff2d84a000 - 0x7fff2d8dfffb com.apple.ink.framework (10.9 - 221) <83976BB8-A423-3AA5-8221-6EB04B3DEF0A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff2d8e0000 - 0x7fff2d8faff7 com.apple.openscripting (1.7 - 174) <C282DFBB-4BF2-3222-87E0-0B560D5B4B2F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff2d91b000 - 0x7fff2d91cfff com.apple.print.framework.Print (12 - 267) <DFC4CE94-F6E6-3DFA-AB88-A13E4C5A7701> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff2d91d000 - 0x7fff2d91fff7 com.apple.securityhi (9.0 - 55006) <1AB48F32-D1CB-3657-A30C-40A7E718A71D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff2d920000 - 0x7fff2d926fff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <2A07BB54-438B-34C9-8061-45403E197ACA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff2da47000 - 0x7fff2da47fff com.apple.Cocoa (6.11 - 22) <3269BC26-0217-39FE-A600-D702656D838B> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff2da55000 - 0x7fff2db0efff com.apple.ColorSync (4.13.0 - 3325) <EAD2D314-E810-33FB-B105-BD30ABB912AD> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff2dc9b000 - 0x7fff2dd2eff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <AF2B41CC-DD7A-34EB-A842-00DC3B8F2E9F> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff2dd95000 - 0x7fff2ddbeffb com.apple.CoreBluetooth (1.0 - 1) <ED48840B-A80A-32C1-8E4B-DEB7A7CD3C1A> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff2ddbf000 - 0x7fff2e115fef com.apple.CoreData (120 - 851) <7361F2EA-2B7F-3259-909F-287BEB443781> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff2e116000 - 0x7fff2e1f9fff com.apple.CoreDisplay (99.14 - 99.14) <9B2B211D-EC0A-3569-BB37-887768CD6105> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff2e1fa000 - 0x7fff2e69dfe7 com.apple.CoreFoundation (6.9 - 1455.300) <CB44B892-64CD-3E32-A518-6D40B1A7033F> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff2e69f000 - 0x7fff2ecaffef com.apple.CoreGraphics (2.0 - 1161.21.5) <6451A561-3A83-37FB-AAA7-3FCE6D95C34C> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff2ecb1000 - 0x7fff2efa0fff com.apple.CoreImage (13.0.0 - 579.5) <B2B60A80-2E10-3EDF-920C-94288E55AE25> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff2f00d000 - 0x7fff2f052fff com.apple.audio.midi.CoreMIDI (1.10 - 88) <EE9A1F14-93BB-3DB1-AD62-064C1F4B6D85> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x7fff2f22f000 - 0x7fff2f325ffb com.apple.CoreMedia (1.0 - 2276.80.4) <67942D16-3658-37FC-B61C-8ED3D4BFBFB9> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff2f326000 - 0x7fff2f374fff com.apple.CoreMediaIO (814.0 - 4995) <2A174DD1-431A-3313-9837-04C7E1B284B6> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff2f375000 - 0x7fff2f375fff com.apple.CoreServices (822.37 - 822.37) <CE816EF2-2B89-3F54-A5C6-D3080B1EFB00> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff2f376000 - 0x7fff2f3eaffb com.apple.AE (735.2 - 735.2) <0938A72B-6A4A-36F1-95B3-5EF6B915CEEE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff2f3eb000 - 0x7fff2f6c2fff com.apple.CoreServices.CarbonCore (1178.4.2 - 1178.4.2) <4692EE3A-11FE-31FD-AF5B-30F892E87A05> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff2f6c3000 - 0x7fff2f6f7fff com.apple.DictionaryServices (1.2 - 284.2) <F1F3EFAE-2562-394D-8FB3-BE22F16CD75A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff2f6f8000 - 0x7fff2f700ffb com.apple.CoreServices.FSEvents (1239.50.2 - 1239.50.2) <FE465894-4235-3CE2-9A97-32D6C6C7D9AD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff2f701000 - 0x7fff2f8bfff7 com.apple.LaunchServices (822.37 - 822.37) <0DB4679F-AE39-3BF3-B39B-549322E355AF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff2f8c0000 - 0x7fff2f970fff com.apple.Metadata (10.7.0 - 1191.8) <F3BD3FD7-208A-31E9-85CD-6E607DDAFEF0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff2f971000 - 0x7fff2f9d1fff com.apple.CoreServices.OSServices (822.37 - 822.37) <564DDE70-0250-346B-B5CC-4AFAC11A7373> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff2f9d2000 - 0x7fff2fa40fff com.apple.SearchKit (1.4.0 - 1.4.0) <97DD9E7D-3567-382B-ACF7-CE0E4FE78D36> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff2fa41000 - 0x7fff2fa65ffb com.apple.coreservices.SharedFileList (71.21 - 71.21) <88991F51-0A75-34FF-8C91-ED0F3C270B7B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff2fd06000 - 0x7fff2fe56fff com.apple.CoreText (352.0 - 578.23) <10DAF601-85A8-3F9C-8B0B-69DC16B95E47> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff2fe57000 - 0x7fff2fe91fff com.apple.CoreVideo (1.8 - 0.0) <0DD4FFDF-E1F1-39D1-8246-5D0D9869F1EA> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff2fe92000 - 0x7fff2ff1dff3 com.apple.framework.CoreWLAN (13.0 - 1350.2) <EC145FBD-F638-38B8-BE94-F892A2F02550> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff30198000 - 0x7fff3019dfff com.apple.DiskArbitration (2.7 - 2.7) <51DC4AED-6F0C-321F-93E3-20EA4341B768> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff3035e000 - 0x7fff30725ffb com.apple.Foundation (6.9 - 1455.300) <0479E072-1DD0-3881-A9A2-EDAD3EE58C23> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff30796000 - 0x7fff307c6ff3 com.apple.GSS (4.0 - 2.0) <7E83A21E-4F90-38F3-9FD3-FAC0E0143243> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff308d8000 - 0x7fff309dcffb com.apple.Bluetooth (6.0.7 - 6.0.7f22) <08E33A6B-16A7-3E4E-82C9-E1E5A84300D0> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff30a3c000 - 0x7fff30ad7fff com.apple.framework.IOKit (2.0.2 - 1445.71.6) <4B5C715C-6A49-366B-9080-ABADE6A3B3BD> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff30ad9000 - 0x7fff30ae0fff com.apple.IOSurface (211.15 - 211.15) <08DA3232-805F-304B-80DD-C86B49CC4AAD> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff30b37000 - 0x7fff30cb2fe7 com.apple.ImageIO.framework (3.3.0 - 1739.3.8) <58BD6865-E629-3283-859B-82C4C3A5FF66> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff30cb3000 - 0x7fff30cb7ffb libGIF.dylib (1739.3.8) <E3446976-10BF-3B75-9A11-32893368D748> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff30cb8000 - 0x7fff30d9ffe7 libJP2.dylib (1739.3.8) <4B440B09-1542-304C-8BE5-EB0F9370046C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff30da0000 - 0x7fff30dc3ff7 libJPEG.dylib (1739.3.8) <F6BCF3DA-6F0B-35A8-982C-BEFD2DD6DBFE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff310b2000 - 0x7fff310d8feb libPng.dylib (1739.3.8) <25C5D4B1-3715-3DF5-BE4B-C71089ADBBFE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff310d9000 - 0x7fff310dbffb libRadiance.dylib (1739.3.8) <5134034F-A7BC-3749-A141-92BC89579AF6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff310dc000 - 0x7fff3112afe7 libTIFF.dylib (1739.3.8) <91F6CDBD-C4A0-3614-81DC-B9A9E3838CF0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff31fe4000 - 0x7fff31ffdff7 com.apple.Kerberos (3.0 - 1) <C7CDC1E0-011B-3220-847D-1AC3DA6D5522> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff322bc000 - 0x7fff322c3fff com.apple.MediaAccessibility (1.0 - 114) <00F21329-1163-3283-A882-A5DD7A12D353> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff322d9000 - 0x7fff32372fff com.apple.MediaPlayer (1.0 - 1.0) <E04A1D72-429F-390E-9542-0DEB46DFB3EA> /System/Library/Frameworks/MediaPlayer.framework/Versions/A/MediaPlayer
0x7fff32373000 - 0x7fff329ddff7 com.apple.MediaToolbox (1.0 - 2276.80.4) <FA444376-E5AF-36AB-BE1D-76ECE4D72049> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff329df000 - 0x7fff32a60fff com.apple.Metal (125.30 - 125.30) <67EDA241-80B1-3C67-BB2B-FF83E49FEF8D> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff32a7d000 - 0x7fff32a98fff com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <8DED0F0C-4A10-36A3-A3E2-7D3CF429ACE1> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff32a99000 - 0x7fff32b08fef com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <48F4A97F-143A-3918-AB92-6733E258E25A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff32b09000 - 0x7fff32b2dfff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <CD443ADC-07FE-3603-B0C9-60C2AF3616FF> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff32b2e000 - 0x7fff32c15ff7 com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <40EB0BAE-6DDE-3334-A28C-529AE4C6716A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff32c16000 - 0x7fff32c16ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <A111E862-43E5-3247-9E98-0A40DC34AD9B> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff33c15000 - 0x7fff33c21ffb com.apple.NetFS (6.0 - 4.0) <02E09301-324F-3542-875D-B87B144635C8> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff36a13000 - 0x7fff36a6dff7 com.apple.opencl (2.8.24 - 2.8.24) <429B5283-276D-372D-BB0E-EEBE1408C393> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff36a6e000 - 0x7fff36a8affb com.apple.CFOpenDirectory (10.13 - 207.50.1) <E9AD4934-5DE3-3DD0-9D7B-9D288D829F15> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff36a8b000 - 0x7fff36a96fff com.apple.OpenDirectory (10.13 - 207.50.1) <8B54C486-14C9-3FEF-97B8-F4D6F59F75CF> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff37c15000 - 0x7fff37c17fff libCVMSPluginSupport.dylib (16.7.4) <3E26CF2B-5074-3321-AD9E-6A667D61AA35> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff37c18000 - 0x7fff37c1dffb libCoreFSCache.dylib (162.12) <D12E1D0E-C0E5-329E-99B4-AB152C9ABBE3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff37c1e000 - 0x7fff37c22fff libCoreVMClient.dylib (162.12) <39951906-8566-3F9D-9EA8-EBD6084DCF73> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff37c23000 - 0x7fff37c2cff3 libGFXShared.dylib (16.7.4) <81A7875B-103D-3C82-B25C-DE24E57E5C8B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff37c2d000 - 0x7fff37c38fff libGL.dylib (16.7.4) <2BB333D3-5C61-33DF-8545-06DF2D08B83D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff37c39000 - 0x7fff37c74fe7 libGLImage.dylib (16.7.4) <4DA003CE-0B74-3FE4-808C-B2FBCE517EB4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff37de3000 - 0x7fff37e21ffb libGLU.dylib (16.7.4) <BCB09CD8-EB0E-38FA-8B5A-9E29532EE364> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff38799000 - 0x7fff387a8ff3 com.apple.opengl (16.7.4 - 16.7.4) <77A788F3-8F0C-305C-AEB9-FF258676C599> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff38b27000 - 0x7fff38c73ff7 com.apple.QTKit (7.7.3 - 3014.8) <F333568C-D990-3BBA-A09B-ABAB5F984905> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff395fc000 - 0x7fff39848ff7 com.apple.QuartzCore (1.11 - 584.64.2) <FD9A3180-479E-3DAC-9CF0-0D214C7E46A7> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff3a080000 - 0x7fff3a3abfff com.apple.security (7.0 - 58286.70.19) <E118FC23-2E20-3999-826B-58488049A277> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff3a3ac000 - 0x7fff3a438ff7 com.apple.securityfoundation (6.0 - 55185.50.5) <3D9AD4EF-439C-3AE1-9332-AD291CF96C64> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff3a46a000 - 0x7fff3a46effb com.apple.xpc.ServiceManagement (1.0 - 1) <3FCAF325-40C8-3148-9E49-E555F95B2946> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff3a813000 - 0x7fff3a883ff3 com.apple.SystemConfiguration (1.17 - 1.17) <41D509AB-AED3-30FF-BB00-615BB5A8AC00> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff3aa38000 - 0x7fff3adb3fff com.apple.VideoToolbox (1.0 - 2276.80.4) <1C94A509-0372-3B58-94BC-4488C042BD79> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff3d780000 - 0x7fff3d813ff3 com.apple.APFS (1.0 - 1) <70034B32-9347-30FB-9DDE-95061F686613> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff3e41f000 - 0x7fff3e447fff com.apple.framework.Apple80211 (13.0 - 1370.4) <C296CDDB-0A79-3D6B-898A-0FBA1892F5AC> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff3e449000 - 0x7fff3e458fef com.apple.AppleFSCompression (96.60.1 - 1.0) <CBE1A092-CE90-36B9-AAA6-0BE2E7921504> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff3e557000 - 0x7fff3e562ff7 com.apple.AppleIDAuthSupport (1.0 - 1) <924EA55F-1C87-347F-9212-F79EA2B2C84C> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff3e59c000 - 0x7fff3e5e4ff3 com.apple.AppleJPEG (1.0 - 1) <15558577-08E3-3087-86A9-8B6247978BCE> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff3e61f000 - 0x7fff3e647fff com.apple.applesauce (1.0 - ???) <9CE4CAE2-30B9-3DF6-9BC0-33D532D7B937> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff3e714000 - 0x7fff3e764ff7 com.apple.AppleVAFramework (5.0.41 - 5.0.41) <C82921AA-1537-3736-BC16-5CABB3EF0100> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff3ea9a000 - 0x7fff3ed33ffb com.apple.AuthKit (1.0 - 1) <C3087797-E472-300E-8B4A-448857ACE8E7> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff3ee6a000 - 0x7fff3ee71ff7 com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <B2A1EEDF-490A-38E2-A896-41057C0417BF> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff3ee72000 - 0x7fff3eef9ff7 com.apple.backup.framework (1.9.6 - 1.9.6) <0A54D219-E71B-3BC6-8DFC-11ED47E431BE> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff408b5000 - 0x7fff408beff3 com.apple.CommonAuth (4.0 - 2.0) <21AF4AC2-E650-35F9-AB33-3EBA2769FBC0> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff40bfa000 - 0x7fff41002fff com.apple.CoreAUC (259.0.0 - 259.0.0) <EF95ED0E-F4F1-3969-89BB-CE8CDD74C29F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff41003000 - 0x7fff41033ff7 com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <6AC79B1F-0A12-34A4-BC0D-5A6A65ABABE0> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff413d2000 - 0x7fff413e2ff7 com.apple.CoreEmoji (1.0 - 69.3) <DCCF04BB-DA33-3DC0-B7C2-1D34870C0C0A> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff416e6000 - 0x7fff416fcff7 com.apple.CoreMediaAuthoring (2.2 - 956) <EE44B61D-6742-3649-A52F-C6AA0431F846> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff41b76000 - 0x7fff41b7eff3 com.apple.CorePhoneNumbers (1.0 - 1) <3B388768-5CDB-341A-BCE2-4047EAD009EA> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff420b4000 - 0x7fff42145fff com.apple.CoreSymbolication (9.3 - 64026.2) <30652FA5-C731-3A22-864D-DF6D9C77CD4C> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff421c8000 - 0x7fff422fdfff com.apple.coreui (2.1 - 494.1) <5B4F3E9C-A4EF-3908-A035-59B8631C3685> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff422fe000 - 0x7fff4242ffff com.apple.CoreUtils (5.6 - 560.11) <2C5A0610-1F08-3603-8692-EE03E62EE622> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff42484000 - 0x7fff424e8fff com.apple.framework.CoreWiFi (13.0 - 1350.2) <500CC54F-A6CB-3D36-9BB1-C9C9F6A6E414> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff424e9000 - 0x7fff424f9ff7 com.apple.CrashReporterSupport (10.13 - 1) <1ADEC140-4838-3976-A14B-6268C5251481> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff42578000 - 0x7fff42587ff7 com.apple.framework.DFRFoundation (1.0 - 191.7) <F7AB1B29-A4B0-3938-AFDC-DAA204929404> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff4258a000 - 0x7fff4258effb com.apple.DSExternalDisplay (3.1 - 380) <13AA3B17-E649-3B7B-B09D-9AE7C4A60887> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff42610000 - 0x7fff42686fff com.apple.datadetectorscore (7.0 - 590.3) <E645FBF0-B47D-3394-84DF-792B85E94CB3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff426d4000 - 0x7fff42714ff7 com.apple.DebugSymbols (181.0 - 181.0) <702DB951-F5A6-3155-9D84-BBA9A4B4E1BD> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff42715000 - 0x7fff42844fff com.apple.desktopservices (1.12.5 - 1.12.5) <96BB57E2-3359-3920-AA7C-BF03C2225485> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff43659000 - 0x7fff43a87fff com.apple.vision.FaceCore (3.3.2 - 3.3.2) <06065DA3-4091-3682-A308-BF3F2E3E4AF8> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff46d4f000 - 0x7fff46d54fff com.apple.GPUWrangler (3.20.18 - 3.20.18) <B54A9063-01EC-3D2C-8924-86A1F315DEA2> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff47aca000 - 0x7fff47ad9fff com.apple.GraphVisualizer (1.0 - 5) <EB42FFAD-2BCA-3DE2-B40E-AFDE6E7FAA4D> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff47b5c000 - 0x7fff47bd0fff com.apple.Heimdal (4.0 - 2.0) <FF7BC1AE-1BA6-3150-A7CC-B9E0AD5EBE7F> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff484e3000 - 0x7fff484eaff7 com.apple.IOAccelerator (378.28 - 378.28) <F109E4CB-49D9-37FB-974A-8A3E9E8A61DA> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff484ee000 - 0x7fff48505fff com.apple.IOPresentment (1.0 - 35.1) <AC89202B-8433-3B62-A7BE-467D1905F6FB> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff488d0000 - 0x7fff488f6ffb com.apple.IconServices (97.6 - 97.6) <7913A453-8D29-31DC-ADDB-7CEC068C9B86> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff48a03000 - 0x7fff48a06ff3 com.apple.InternationalSupport (1.0 - 1) <D020C355-DCC1-3D7E-8FCE-BD6FF441824D> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff48a74000 - 0x7fff48a84ffb com.apple.IntlPreferences (2.0 - 227.5.2) <E036B12B-6017-3EF6-9E73-71DCE8036608> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff48b7b000 - 0x7fff48b8eff3 com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <B999BEF6-F3E7-30EE-9177-FBC8E826659D> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff48b8f000 - 0x7fff48c84ff7 com.apple.LanguageModeling (1.0 - 159.5.3) <FAA236D6-CFB8-37D2-B635-B324E0719E32> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff48c85000 - 0x7fff48cc7fff com.apple.Lexicon-framework (1.0 - 33.5) <F8DD2D09-5CEE-3741-93CF-223FC61FCCA4> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff48ccb000 - 0x7fff48cd2ff7 com.apple.LinguisticData (1.0 - 238.3) <6F2ED02A-2120-3ABA-8EC1-314E4FFE77F3> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff494d3000 - 0x7fff494d6fff com.apple.Mangrove (1.0 - 1) <471F4581-5235-3381-B16B-CE92ED6CF086> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff49626000 - 0x7fff4994fff7 com.apple.MediaRemote (1.0 - 1) <1FE6F7B0-E949-36F3-9646-1B85BA1BAF20> /System/Library/PrivateFrameworks/MediaRemote.framework/Versions/A/MediaRemote
0x7fff49950000 - 0x7fff49971fff com.apple.MediaServices (1.0 - 1) <7AE9BD6D-594B-319E-A750-D0607150BAE1> /System/Library/PrivateFrameworks/MediaServices.framework/Versions/A/MediaServices
0x7fff499e6000 - 0x7fff49a4fff7 com.apple.gpusw.MetalTools (1.0 - 1) <F2A47319-0430-3BB5-943E-651A40C127A9> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff49d58000 - 0x7fff49d71fff com.apple.MobileKeyBag (2.0 - 1.0) <9EA31672-3B83-3ABF-B2D5-8584E159051E> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff49dfd000 - 0x7fff49e27ffb com.apple.MultitouchSupport.framework (1614.1 - 1614.1) <A376F2FB-64AE-3B35-88B0-7D2BB4D1CB7C> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff4a08e000 - 0x7fff4a099fff com.apple.NetAuth (6.2 - 6.2) <85C5D94D-C67E-36DC-B0EA-02F53AC4FCD3> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff4b935000 - 0x7fff4b945ffb com.apple.PerformanceAnalysis (1.194 - 194) <B6934994-BD69-36F9-914E-6BBDCD797612> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff4d704000 - 0x7fff4d722fff com.apple.ProtocolBuffer (1 - 260) <195906B1-1DB1-3AD2-B2F7-87B867C27F40> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff4d8ec000 - 0x7fff4d8f8fff com.apple.xpc.RemoteServiceDiscovery (1.0 - 1205.70.16) <AEAA88C6-CBB6-3598-9548-E4DF155B4A64> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff4d8f9000 - 0x7fff4d91cffb com.apple.RemoteViewServices (2.0 - 125) <695CBF89-C15C-3E4C-8045-B46DCA64E3FB> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff4d91d000 - 0x7fff4d932ff3 com.apple.xpc.RemoteXPC (1.0 - 1205.70.16) <DD597F26-6BBE-3DAD-9257-7A5FCD60C109> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
0x7fff4f242000 - 0x7fff4f357ff7 com.apple.Sharing (1050.22.9 - 1050.22.9) <CAB71093-B187-363E-BBAA-B0D23D7642AA> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff4f382000 - 0x7fff4f383ff7 com.apple.performance.SignpostNotification (1.2.6 - 2.6) <E77879A4-B040-3BE0-86F5-98173A4100AD> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/SignpostNotification
0x7fff500e1000 - 0x7fff5037efff com.apple.SkyLight (1.600.0 - 312.103.12) <A65B547C-B7CA-3E33-A0C5-58AB436A8467> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff50b47000 - 0x7fff50b54fff com.apple.SpeechRecognitionCore (4.6.1 - 4.6.1) <90CDCEAD-5A65-3C35-9370-2B306895E97C> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff516fa000 - 0x7fff51783fc7 com.apple.Symbolication (9.3 - 64033) <F576D527-4CB1-34A5-B15E-1130833EEDAB> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff51cf4000 - 0x7fff51cfcff7 com.apple.TCC (1.0 - 1) <9D5466C6-A8B6-3C24-A791-6506B81D9998> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff51f09000 - 0x7fff51fc6ff7 com.apple.TextureIO (3.7 - 3.7) <32C460CD-E93D-3FA5-A4AE-CA648722F5FE> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff52077000 - 0x7fff52227fff com.apple.UIFoundation (1.0 - 547.9) <D0994333-5EB4-3415-8D18-2A0487AE91E0> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff52efc000 - 0x7fff52fcbff7 com.apple.ViewBridge (343.2 - 343.2) <0A295791-B763-3E58-A9DD-8E4F40E815C9> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff539a3000 - 0x7fff539a5ffb com.apple.loginsupport (1.0 - 1) <E273A65A-6379-3787-B119-BC6ED94D4A81> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff53b0c000 - 0x7fff53b3fff7 libclosured.dylib (551.5) <112BC241-6626-3848-8DD8-B34B5B6F7ABC> /usr/lib/closure/libclosured.dylib
0x7fff53bf9000 - 0x7fff53c32ff7 libCRFSuite.dylib (41) <14B00FCF-4C67-3736-95B5-76FEA6E4972C> /usr/lib/libCRFSuite.dylib
0x7fff53c33000 - 0x7fff53c3efff libChineseTokenizer.dylib (28) <2237A259-0E59-3DD0-BADC-281C361FAB70> /usr/lib/libChineseTokenizer.dylib
0x7fff53cd0000 - 0x7fff53cd1ff3 libDiagnosticMessagesClient.dylib (104) <3F855622-352B-3EA8-B7C8-94D1DB48C080> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff53d08000 - 0x7fff53ed2ff3 libFosl_dynamic.dylib (17.8) <1A2A9D53-129E-3F7D-AE23-1D6E6D9EA017> /usr/lib/libFosl_dynamic.dylib
0x7fff53f0a000 - 0x7fff53f0afff libOpenScriptingUtil.dylib (174) <AC38B2C3-5A37-30EB-A246-CEFABD3DD4E7> /usr/lib/libOpenScriptingUtil.dylib
0x7fff54041000 - 0x7fff54045ffb libScreenReader.dylib (562.18.5) <FFB20E40-7669-30F6-8577-B74E18076376> /usr/lib/libScreenReader.dylib
0x7fff54046000 - 0x7fff54047ffb libSystem.B.dylib (1252.50.4) <5A02016C-8F9D-3F47-8C39-AD2CD4F9F11D> /usr/lib/libSystem.B.dylib
0x7fff540da000 - 0x7fff540dafff libapple_crypto.dylib (109.50.15) <A8DEA8E9-5769-3C78-824D-969A98B94086> /usr/lib/libapple_crypto.dylib
0x7fff540db000 - 0x7fff540f1ff7 libapple_nghttp2.dylib (1.24) <24338D88-5D73-3165-9CFB-5A92734C9040> /usr/lib/libapple_nghttp2.dylib
0x7fff540f2000 - 0x7fff5411cff3 libarchive.2.dylib (54) <D2B6AD30-18CB-3E3C-ABBF-A0745654350F> /usr/lib/libarchive.2.dylib
0x7fff5411d000 - 0x7fff5419efdf libate.dylib (1.13.1) <77603BB8-681D-32A6-966E-4F92B9165447> /usr/lib/libate.dylib
0x7fff541a2000 - 0x7fff541a2ff3 libauto.dylib (187) <92E693DF-D74D-39A0-99AB-8A9F6FFEBA18> /usr/lib/libauto.dylib
0x7fff541a3000 - 0x7fff5425cffb libboringssl.dylib (109.50.15) <FC25FE02-6AA8-3F0B-9EF3-56A455C08C0F> /usr/lib/libboringssl.dylib
0x7fff5425d000 - 0x7fff5426dff3 libbsm.0.dylib (39) <18D57879-A717-3466-9637-1704EE59A32A> /usr/lib/libbsm.0.dylib
0x7fff5426e000 - 0x7fff5427bffb libbz2.1.0.dylib (38) <0B4321CD-3D6F-3095-A12E-27F66B4321AD> /usr/lib/libbz2.1.0.dylib
0x7fff5427c000 - 0x7fff542d2fff libc++.1.dylib (400.9) <142D6292-F30F-3949-9F37-3C97A579F540> /usr/lib/libc++.1.dylib
0x7fff542d3000 - 0x7fff542f7ff7 libc++abi.dylib (400.8.2) <EF5E37D7-11D9-3530-BE45-B986612D13E2> /usr/lib/libc++abi.dylib
0x7fff542f9000 - 0x7fff54309fff libcmph.dylib (6) <890DEC4C-4334-393C-8B56-7C8560BBED9D> /usr/lib/libcmph.dylib
0x7fff5430a000 - 0x7fff54321fcf libcompression.dylib (47.60.2) <543F07BF-2F2F-37D5-9866-E84BF659885B> /usr/lib/libcompression.dylib
0x7fff545cc000 - 0x7fff545e4ff7 libcoretls.dylib (155.50.1) <087E9F90-21E5-376D-9956-C4E346409682> /usr/lib/libcoretls.dylib
0x7fff545e5000 - 0x7fff545e6ff3 libcoretls_cfhelpers.dylib (155.50.1) <78CCDD10-7D71-365E-A0A5-8524ED5F5BF9> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff54ab7000 - 0x7fff54b0cff3 libcups.2.dylib (462.2.10) <590D6ACC-68A0-371E-8646-FC59F814534B> /usr/lib/libcups.2.dylib
0x7fff54c4c000 - 0x7fff54c4cfff libenergytrace.dylib (16) <1F11D488-07C6-3D18-BEF2-0B28A992D761> /usr/lib/libenergytrace.dylib
0x7fff54c4d000 - 0x7fff54c66ff3 libexpat.1.dylib (16.1.1.1) <BF67821E-1B05-3E26-9EE9-4366CC0DAD03> /usr/lib/libexpat.1.dylib
0x7fff54c83000 - 0x7fff54c88ff3 libheimdal-asn1.dylib (520.50.9) <EF65C17E-31CD-31DC-876C-BF3EF393099C> /usr/lib/libheimdal-asn1.dylib
0x7fff54cb4000 - 0x7fff54da5ff7 libiconv.2.dylib (51.50.1) <7965B866-C75A-3450-9891-0500349F7090> /usr/lib/libiconv.2.dylib
0x7fff54da6000 - 0x7fff54fcdffb libicucore.A.dylib (59181.0.1) <17767680-09DF-3954-AB6C-B13B41F92A2E> /usr/lib/libicucore.A.dylib
0x7fff5501a000 - 0x7fff5501bfff liblangid.dylib (128) <C54A2059-A4BE-364B-94C2-581C548459BC> /usr/lib/liblangid.dylib
0x7fff5501c000 - 0x7fff55035ffb liblzma.5.dylib (10) <60BEAB81-CE65-3479-90CC-03325AACEC95> /usr/lib/liblzma.5.dylib
0x7fff55036000 - 0x7fff5504cff7 libmarisa.dylib (9) <47540053-02CF-35F8-A75E-074DB3D51812> /usr/lib/libmarisa.dylib
0x7fff550fd000 - 0x7fff55325ff7 libmecabra.dylib (779.7.6) <B2ACB6A9-91AE-364B-9418-8EB938BF82B6> /usr/lib/libmecabra.dylib
0x7fff554fd000 - 0x7fff55678fff libnetwork.dylib (1229.70.2) <0596A03E-C984-3FE6-B88E-63D5F96EC49A> /usr/lib/libnetwork.dylib
0x7fff556ff000 - 0x7fff55aed7e7 libobjc.A.dylib (723) <843EFB54-EFCC-3A7C-BE11-092B6A556262> /usr/lib/libobjc.A.dylib
0x7fff55b00000 - 0x7fff55b04fff libpam.2.dylib (22) <E5840D63-8506-301A-9182-5000031854E1> /usr/lib/libpam.2.dylib
0x7fff55b07000 - 0x7fff55b3fff7 libpcap.A.dylib (79.20.3) <6A9D27FA-2780-3E96-8B2E-645638AC13AC> /usr/lib/libpcap.A.dylib
0x7fff55bbe000 - 0x7fff55bdaffb libresolv.9.dylib (65.1) <D9BB6307-71E4-3A94-A745-1FCA114C6894> /usr/lib/libresolv.9.dylib
0x7fff55c29000 - 0x7fff55c2aff3 libspindump.dylib (252) <7BE3801C-F1F5-3F54-AB70-9842F8EF3F09> /usr/lib/libspindump.dylib
0x7fff55c2b000 - 0x7fff55dbeff7 libsqlite3.dylib (274.8.1) <FCAD6A57-829E-3701-B16E-1833D620E0E8> /usr/lib/libsqlite3.dylib
0x7fff55f92000 - 0x7fff55ff2ff3 libusrtcp.dylib (1229.70.2) <1E065228-D0E3-3808-9405-894056C6BEC0> /usr/lib/libusrtcp.dylib
0x7fff55ff3000 - 0x7fff55ff6ffb libutil.dylib (51.20.1) <A50E15F1-20A2-3EA7-A8CE-A43662E18587> /usr/lib/libutil.dylib
0x7fff55ff7000 - 0x7fff56004ff3 libxar.1.dylib (417.1) <351781D5-3CCF-320F-BB5A-4DFCC1CCD31D> /usr/lib/libxar.1.dylib
0x7fff56008000 - 0x7fff560efffb libxml2.2.dylib (31.20) <286F8531-7001-3989-9640-284443355433> /usr/lib/libxml2.2.dylib
0x7fff560f0000 - 0x7fff56118fff libxslt.1.dylib (15.16) <57D56366-1E7B-356C-B2B8-F4688FF666E6> /usr/lib/libxslt.1.dylib
0x7fff56119000 - 0x7fff5612bffb libz.1.dylib (70) <47278BDC-596E-3037-B8DA-05FE9D5DBEF6> /usr/lib/libz.1.dylib
0x7fff561c7000 - 0x7fff561cbff7 libcache.dylib (80) <096D3699-58D2-3D23-9512-BC88DAE7B16C> /usr/lib/system/libcache.dylib
0x7fff561cc000 - 0x7fff561d6ff3 libcommonCrypto.dylib (60118.50.1) <B4E77BD4-A809-37E1-8A79-25955E0F5D9C> /usr/lib/system/libcommonCrypto.dylib
0x7fff561d7000 - 0x7fff561defff libcompiler_rt.dylib (62) <4CEED002-D00B-35F8-B563-0546A5F71A43> /usr/lib/system/libcompiler_rt.dylib
0x7fff561df000 - 0x7fff561e8ffb libcopyfile.dylib (146.50.5) <F7A7999F-9509-3C67-8EE9-95BEE6772676> /usr/lib/system/libcopyfile.dylib
0x7fff561e9000 - 0x7fff5626effb libcorecrypto.dylib (562.70.3) <9C6E5CC2-272B-3740-AEDB-9EBEC98EC7F9> /usr/lib/system/libcorecrypto.dylib
0x7fff562f6000 - 0x7fff5632fff7 libdispatch.dylib (913.60.3) <285526B6-A2A6-316D-A1CC-37803B71E203> /usr/lib/system/libdispatch.dylib
0x7fff56330000 - 0x7fff5634dff7 libdyld.dylib (551.5) <49ABA86D-DD48-3133-9B14-B9A564EEBC66> /usr/lib/system/libdyld.dylib
0x7fff5634e000 - 0x7fff5634effb libkeymgr.dylib (28) <7CC7B5E1-AB7F-3495-A26A-396461BCB66B> /usr/lib/system/libkeymgr.dylib
0x7fff5634f000 - 0x7fff5635bff3 libkxld.dylib (4570.71.82.8) <44AF05D7-6BDF-3A9B-B5CF-D16C98B6844E> /usr/lib/system/libkxld.dylib
0x7fff5635c000 - 0x7fff5635cff7 liblaunch.dylib (1205.70.16) <265EE555-E988-3EE5-A39E-028FB3A5FE11> /usr/lib/system/liblaunch.dylib
0x7fff5635d000 - 0x7fff56361ffb libmacho.dylib (906) <F5F16E2F-F961-3FF4-B02F-69BBDB57B8DC> /usr/lib/system/libmacho.dylib
0x7fff56362000 - 0x7fff56364fff libquarantine.dylib (86.70.1) <262CECFE-A493-3EC6-8608-CEA93757265E> /usr/lib/system/libquarantine.dylib
0x7fff56365000 - 0x7fff56366ff3 libremovefile.dylib (45) <EA24BFB6-24B7-3841-8AAC-FAF400910706> /usr/lib/system/libremovefile.dylib
0x7fff56367000 - 0x7fff5637efff libsystem_asl.dylib (356.70.1) <9481D82D-CFB7-3032-A07F-88F7F59CAC2C> /usr/lib/system/libsystem_asl.dylib
0x7fff5637f000 - 0x7fff5637ffff libsystem_blocks.dylib (67) <FA2C3663-9DBB-3AFB-80A3-E77BE0816AD0> /usr/lib/system/libsystem_blocks.dylib
0x7fff56380000 - 0x7fff56409ff7 libsystem_c.dylib (1244.50.9) <25DD83D8-80CA-3DFF-8626-FE704911F19C> /usr/lib/system/libsystem_c.dylib
0x7fff5640a000 - 0x7fff5640dffb libsystem_configuration.dylib (963.50.9) <61B26E1D-FEFF-38C6-AE0E-A6DD90145EB2> /usr/lib/system/libsystem_configuration.dylib
0x7fff5640e000 - 0x7fff56411ffb libsystem_coreservices.dylib (51) <E8FA663F-1B0F-3B12-8F97-31A46E6B4D68> /usr/lib/system/libsystem_coreservices.dylib
0x7fff56412000 - 0x7fff56413fff libsystem_darwin.dylib (1244.50.9) <6195EEA1-83A7-35F0-8147-5AB031020CD0> /usr/lib/system/libsystem_darwin.dylib
0x7fff56414000 - 0x7fff5641affb libsystem_dnssd.dylib (878.70.4) <0D2C9583-5D28-375B-AEB4-F66F18C78322> /usr/lib/system/libsystem_dnssd.dylib
0x7fff5641b000 - 0x7fff56464ff7 libsystem_info.dylib (517.30.1) <9C2C96F3-638B-34E7-A2BD-24C643EAF957> /usr/lib/system/libsystem_info.dylib
0x7fff56465000 - 0x7fff5648bff7 libsystem_kernel.dylib (4570.71.82.8) <C34BA704-FAFF-3DDB-9827-5930B5BEF134> /usr/lib/system/libsystem_kernel.dylib
0x7fff5648c000 - 0x7fff564d7fcb libsystem_m.dylib (3147.50.1) <B3172533-77D2-3416-8487-4A505198E9E1> /usr/lib/system/libsystem_m.dylib
0x7fff564d8000 - 0x7fff564f7ff7 libsystem_malloc.dylib (140.50.7) <821E16C8-7A7E-3269-9167-10F4F413BF93> /usr/lib/system/libsystem_malloc.dylib
0x7fff564f8000 - 0x7fff56628ff7 libsystem_network.dylib (1229.70.2) <07BFD80A-E7EB-3DEB-B765-5E1659453114> /usr/lib/system/libsystem_network.dylib
0x7fff56629000 - 0x7fff56633ffb libsystem_networkextension.dylib (767.70.2) <A90BAFFD-AC3D-3078-90B2-71463DBFD4A5> /usr/lib/system/libsystem_networkextension.dylib
0x7fff56634000 - 0x7fff5663dff3 libsystem_notify.dylib (172) <738B3BB0-4F20-3446-A3B6-095D796E5903> /usr/lib/system/libsystem_notify.dylib
0x7fff5663e000 - 0x7fff56645ff7 libsystem_platform.dylib (161.50.1) <90A2A62F-8690-3FA7-A4D0-9085BF2FA44A> /usr/lib/system/libsystem_platform.dylib
0x7fff56646000 - 0x7fff56651fff libsystem_pthread.dylib (301.50.1) <283E64A7-A2B2-3212-95BA-4D21F9AE36CF> /usr/lib/system/libsystem_pthread.dylib
0x7fff56652000 - 0x7fff56655fff libsystem_sandbox.dylib (765.70.2) <C29E1B7A-F39B-344E-98F7-8FB32B10AE0A> /usr/lib/system/libsystem_sandbox.dylib
0x7fff56656000 - 0x7fff56657ff3 libsystem_secinit.dylib (30) <4E84DF62-57B5-36F9-819F-3C1E7FEDA856> /usr/lib/system/libsystem_secinit.dylib
0x7fff56658000 - 0x7fff5665fff7 libsystem_symptoms.dylib (820.60.3) <A45B4D84-2C69-3F19-83C2-2F1EEA73A7B5> /usr/lib/system/libsystem_symptoms.dylib
0x7fff56660000 - 0x7fff56674ff7 libsystem_trace.dylib (829.70.2) <4C4E5351-E370-3226-9B30-61E250DE3B2E> /usr/lib/system/libsystem_trace.dylib
0x7fff56676000 - 0x7fff5667bff7 libunwind.dylib (35.3) <BAE12DA3-CF33-32AD-86B0-CCD6705ADFAA> /usr/lib/system/libunwind.dylib
0x7fff5667c000 - 0x7fff566a9fff libxpc.dylib (1205.70.16) <26D99819-B813-320E-9E8F-9D57AD2DA63B> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 8263
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=358.2M resident=0K(0%) swapped_out_or_unallocated=358.2M(100%)
Writable regions: Total=38.7M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=38.7M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Activity Tracing 256K 2
Kernel Alloc Once 8K 2
MALLOC 30.2M 18
MALLOC guard page 32K 9
STACK GUARD 56.0M 2
Stack 8192K 2
__DATA 25.3M 249
__FONT_DATA 4K 2
__LINKEDIT 193.5M 5
__TEXT 164.7M 250
__UNICODE 560K 2
shared memory 12K 4
TOTAL 478.7M 535
Model: MacBookPro11,3, BootROM 162.0.0.0.0, 4 processors, Intel Core i7, 2.5 GHz, 16 GB, SMC 2.19f12
Graphics: Intel Iris Pro, Intel Iris Pro, Built-In
Graphics: NVIDIA GeForce GT 750M, NVIDIA GeForce GT 750M, PCIe
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x134), Broadcom BCM43xx 1.0 (7.77.37.33.1a1)
Bluetooth: Version 6.0.7f22, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM0512F, 500.28 GB
USB Device: USB 3.0 Bus
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 17.1
Cablecr69
Postby support » 08 May 2024, 21:20
And what happens with a new empty lightghow ?
Does V9.3.14 run correctly, or does it crash too ?
Return to General software
