Page 3 of 4
Re: request - global Offset
PostPosted: 12 June 2019, 06:56
Thank you for the feedback.
Good news !
PostPosted: 12 June 2019, 09:05
by Niffo
@TimH :
If you are able to reproduce : "This update seemed to cause a crash elsewhere in the software. When attempting to edit the channels of a master fader, the software crashes.", we are interested on how to do.
PostPosted: 19 June 2019, 14:36
by tcld
DeeStage wrote:I would be very nice if we can type in a number for the offset of each fixture.
At this time its nearly unpossible to set the pan offset of 8 fixtures to the same value.
moving 8 faders to the same spot is really difficult
This feature was very helpful with a show this week, but it would have been even better if I could put have put in a precise number in addition to having the slider capability.
PostPosted: 19 June 2019, 15:41
Noted.
PostPosted: 19 June 2019, 17:42
by DeeStage
Thank you very much for this feature.
+1 for the ability to type in a number of offset for each fixture
+/-100 % would not be the best way to set an offset for my moving lights because it would not be accurate enough.
Is it possible to increase or decrease the PAN/TILT channels by an absolute ammount of DMX Value ?
For instance:
Create a steps scene with PAN at 128 so that all movers will loock straight to front
Open global offset menu and add or decrease the DMX output by
fixture 1: Pan -5 / Pan fine +165
fixture2: Pan +3 /Pan fine +100
The pan fine channel is really nessecary for me becaus im working with Beam moving heads.
without the fine channels its not possible to create an symmetrical parallel look..
I hope you understand what i mean
PostPosted: 20 June 2019, 23:46
by muscanto
DeeStage wrote:Thank you very much for this feature.
For instance:
It would be ideal to be able to choose between percent and actual DMX value but if I had to pick one, I would pick absolute DMX value.
PostPosted: 25 June 2019, 16:52
It is now possible to visualize/enter the value in a string box.
Available in the fix file.
Re: request - global Offset [done]
PostPosted: 26 June 2019, 13:20
by muscanto
Really like this last update allowing us to type in values!!
I am curious though, the number scheme for the value's has a very high range. How is the software using this value to calculate the offset? Is it done by percentage of 255 ?
PostPosted: 26 June 2019, 14:08
No, this is a dmx value in 16bits.
PostPosted: 26 June 2019, 14:11
by muscanto
support wrote:No, this is a dmx value in 16bits.
Ah, that makes perfect sense! Thanks.
