Seperate scenes running at same time on Stand Alone
Postby alhuddart » 09 April 2019, 14:36
Hi there
I have a venue with a 512+ running a light rig. I have to replace a couple of lights that have failed. The new lights are different models, and therefore I have to do new programming for a couple of moving heads. My issue is - I seem to remember if the scenes loaded into seperate timelines on the same button are a different length they don't loop correctly, the shorter scene stops before the longer one is finished - is my memory serving me correctly on this ? Any help welcomed ASAP! Many thanks.
alhuddart
Re: Seperate scenes running at same time on Stand Alone
Postby support » 09 April 2019, 16:54
It is important to know that the scenes are not looping in the timeline of the tab StandAlone.
So when there is two different scenes in two different timelines, you have to repeat the block with the shortest scene until both timelines end at the same time.
FYI, you can check the generated scene before uploading it.
It is here: "../YourLightshow/StandAlone/scenes/".
You can open it in the tab "Steps".
Return to StandAlone
