Crash when using a Midi command to pause a timeline [fixed]
Postby spielberger » 10 November 2017, 20:03
Dear Support,
I'm working on a music show using timelines for audio and light. The show is not yet completed but I tried to run the already finished timelines by MIDI commands. But there is a serious issue with MIDI which causes the complete software to crash. I don't know if it is because of our slightly new workflow, but I don't think so.
My Workflow
What I basically do is run timelines for a seqeunce of one or two songs. Between the sequences/songs - at the end of a timeline - I manually activate an "intermission"-scene (called MOD_MAIN) on another page to load a new timeline in the background. When the talent starts the next song the next timeline is played and the MOD_MAIN-scene is switched off using single-button-mode on the intermission-page at the same time the timeline starts - this allows a smooth transition. This has worked for 5 shows on all older software versions!
But now we wanted to add more videoscreens so we have to roughly synchronize the start of a timeline with an external videoplayer. Due to different filesizes sweetlight has slightly different loading-times, I simply worked around this by adding a pause at the first second of the timeline and then sending synchronized MIDI Cues to two different systems - one is Sweetlight playing the preloaded audio and light timeline - the other triggers a video on the external player. So I updated to Version 8.2.27 to have the great new feature of controlling the Timeline-PLAY-Button via MIDI. Because my show is completly triggered by a MIDI-command cuelist.
The Bug
With just one timeline it worked fine BUT by switching to the next I encountered a serious bug: When a MIDI device is activated or present, the stopping of a running timeline causes Sweetlight to crash completly. There is no way around it execpt disabling the MIDI devices. I made a video showing the complete problem: https://drive.google.com/open?id=10ZCEK ... Luxnd3Rpcs
I uploaded my show so that I can send it to you if you want to take a look.
System: Windows 10 - 64bit
Version: 8.2.27
Thanks for your help and support!!!
spielberger
Re: BUG - Crash when stopping Timelines while MIDI activated
Postby spielberger » 10 November 2017, 20:23
I forgot to mension one important thing :shock:
IF THERE IS NO MIDI-COMMAND FOR PLAY/PAUSE it doesn't crash! You will see it in the video in at last minute.
spielberger
Postby support » 10 November 2017, 23:21
Please unzip and install this file in your software folder https://download.thelightingcontroller. ... _Debug.zip
And make again your tests.
You should see more informations regarding the error in a window, when the crash occurs.
Then please post a screenshot of the error message.
Postby spielberger » 11 November 2017, 10:20
I attached the error message - couldn't see more than that, because when the software crashes the debug disappers after 1 - 2 seconds.
[image]
spielberger
Postby support » 11 November 2017, 18:35
Thank you.
Please post a link with a zip of your lightshow (https://thelightingcontroller.com/viewt ... ?f=3&t=168).
Postby spielberger » 11 November 2017, 19:45
support wrote:Thank you.
Done via mail
spielberger
Postby support » 13 November 2017, 08:27
Thank you for your clear and precise reports.
Thank to them, we were able to reproduce easily the crash.
It is normally fixed in the "fix" file.
https://thelightingcontroller.com/viewt ... =85&t=3438
Please try it, and let us know the result.
Postby spielberger » 13 November 2017, 18:43
YES! The fix did the trick! It works now without a problem.
THAT‘S WHAT I CALL SUPPORT! Thanks a lot.
spielberger
Re: Crash when using a Midi command to pause a timeline [fix
Postby support » 13 November 2017, 18:53
Good news !
Thank you for the feedback.
Return to Live - TimeLine
