Shift Slider via Midi [fixed]
Postby DJDaveSA » 25 April 2020, 12:51
Hey Everyone
I have looked but have not been able to find a way of assigning a Shift Slider to a Master Fader to manually (via Midi) adjust the amount of shift.
Aim is to have several LED RGB fixtures all be the fading or snapping to the same color and by just moving a fader be able to change the look quickly and seamlessly?
if there is no current way then consider this a feature request? :roll:
My first post all the way from South Africa
Thanks and keep up the good work! :D
DJDaveSA
Re: RGB Shift Slider to a Master Fader
Postby support » 25 April 2020, 15:08
Please read this for all slider / fader possibilities: https://thelightingcontroller.com/viewt ... =72&t=3647
Postby DJDaveSA » 25 April 2020, 16:31
Thank you for your prompt reply.
I did look at that page.
so it is not possible to adjust the shift slider via midi?
Can we see if other people would be interested in that being a feature that they may find useful with a "+1"
DJDaveSA
Postby support » 27 April 2020, 07:58
All slider into buttons can be controlled via midi (popup menu "Button trigger").
Just link a midi slider.
Re: Shift Slider via Midi [fixed]
Postby DJDaveSA » 27 April 2020, 10:04
Thank you.
I had never thought of that. I had used that to turn the generated scene on and off.
I have tested it and it is working.
DJDaveSA
Return to Live - Buttons
