Modifying Live Screen Faster
Postby mondinga » 12 September 2016, 00:37
There needs to be a more efficient way to move scenes on the live screen. Make a tool bar or tool window that you click "enable". Then you select the scene you want to move and clock up,down,left or right. If you want to move another scene, click on it and move it. Continue doing this until you have moved all of your scenes. When you are finished, turn off the move tool and you are done. This would reduce the number of clicks needed to move your scenes.
This same process could be used for changing the colors on your scenes. "Enable" the color tool, which gives you a color wheel to choose colors. Hold down your CTRL key on your computer, select all of the scenes that you want to change the color, then select the color on the color wheel. Boom!, they all change. When finished, turn off the color tool.
Both of the above tools could be docked into your tool bar or could be floating.
Thank you for reading. Hopefully something like this could save time on programming. :D
mondinga
Re: Modifying Live Screen Faster
Postby support » 12 September 2016, 07:48
This is already possible for moving buttons.
Return to Live - Buttons
Users browsing this forum: No registered users and 48 guests
