Small red dots in the view [fixed]
Postby jwhite » 01 January 2017, 22:18
What are these dots? They seem to affect my non pixel fixtures, but I can't figure out how to delete them.
[image]
jwhite
Re: Dots
Postby support » 02 January 2017, 09:02
Looks like visual glitches.
Please ignore them.
We are not able to reproduce them.
If you can do this easily, please send us your lightshow, and tell us your Operating System.
Re: Dots
Postby Niffo » 02 January 2017, 11:18
Seems to be 0x0 matrix fixtures, you should be able to delete them by editing the "fixtures.ini" file in the Pixels directory of your lightshow.
Re: Dots
Postby support » 02 January 2017, 14:45
You can also post the file ("home_directory/TheLightingController/LightShows/YourLightshow/Pixels/fixtures.ini").
We will check it.
Re: Dots
Postby jwhite » 03 January 2017, 18:17
See attached.
fixtures.ini
(2.41 KiB) Downloaded 834 times
jwhite
Re: Dots
Postby Niffo » 03 January 2017, 22:29
Fixtures_4 to Fixtures_8 have PixelWidth = 0 and PixelHeight = 0, that's the problem.
You can change PixelWidth and PixelHeight to 1 for example or you can delete Fixtures_4 to Fixtures_8 sections (lines 74 to 158) as in the attached file.
If you are able to reproduce this, please let us know how to.
fixtures.ini
(1.35 KiB) Downloaded 825 times
Re: Small red dots in the view [fixed]
Postby jwhite » 04 January 2017, 14:07
Thanks for the updated file. That did correct the issue!
jwhite
Return to Pixels
