Request - Separate fader timer per scene
create scenes with steps
Postby GermanTacos » 15 November 2017, 01:22
Currently in ShowXPress, it's only possible to toggle a global 'fade out' time from the Live preferences menu, however it is possible to make a fade in that is specific to the scene in the steps editor by using the 'duration' number. Would it be possible to get a fade out timer that can be customized for each different scene?
GermanTacos
Re: Feature Request - Separate fader timer per scene
Postby support » 15 November 2017, 09:46
In "Live > Buttons", the fade in/out time is forced only when the button has the "fade in/out" option .
When the button does not have this option, the channels with the "fade/snap" option (below the vertical fader) set to "fade" will fade with the duration time fixed in the first step.
FYI, in "Live > Sequential List". the fade in/out times can be individually overrided.
Postby GermanTacos » 21 November 2017, 00:36
support wrote:When the button does not have this option, the channels with the "fade/snap" option (below the vertical fader) set to "fade" will fade with the duration time fixed in the first step.
I might just be dense, but I'm not seeing the fade/snap option, and I don't see a vertical fader slider option either.
GermanTacos
Re: Request - Separate fader timer per scene
Postby support » 21 November 2017, 08:56
These options are in the tab "Editor > Steps".
Postby SeekLighting » 21 November 2017, 23:46
Are you running version 8? Also the vertical slider fader option should be visible once you turn a steps scene into a fader scene by right clicking it and selecting the option.
Return to Editor - Steps
