Yes it's crazy. When you first select the colorrail then a mono light it crashes but it you go back and ctrl select the colorrail again it won't crash but only because selecting it again only moves the first rgb colors. It's when you try to adjust all the colors together that it crashes.
Thanks.
Crash with colorwheel and multi-RGB fixtures [fixed]
Re: Crash with colorwheel and multi-RGB fixtures [fixed]
Fixed in V8.1.15.
viewtopic.php?f=2&t=4528
Just updated. Now it won't see my dmx512 dongle
Whew!! Fixed. I thought I had a 32 bit but it was a 64 bit so the driver wasn't working. It's fixed now after outing in the correct driver.
