Reverse Pan Tilt Offset? [fixed]
Postby ShowXpressguy200 » 19 February 2020, 23:50
I have (2) Chuavet 255 Inimidator Moving heads but if I set one of the fixtures to "reverse pan and tilt" they don't match vertically. The 2nd spot is a few degrees higher than the other. Once I remove the reverse pan tilt they are back at the same height. Has anyone seen this before? Do I need to manually edit the fixture offset tilt to fix the reverse pan and tilt?
ShowXpressguy200
Re: Reverse Pan Tilt Offset?
Postby ShowXpressguy200 » 20 February 2020, 00:02
I forgot to mention that the settings are identical with the exception of the reverse pan and tilt.
[Fixture17]
address = 300
name = Intimidator Spot 255 IRC (13CH)
model = Intimidator Spot 255 IRC (13CH)
quantity = 1
group = b
id = 1577782326
offset_pan = 0
offset_tilt = 0
zoom_pan = 0
zoom_tilt = 0
[Fixture18]
address = 315
name = Intimidator Spot 255 IRC (13CH) #2
quantity = 1
group = b
id = 1577782363
reverse_pan = yes
reverse_tilt = yes
offset_pan = 0
offset_tilt = 0
zoom_pan = 0
zoom_tilt = 0
ShowXpressguy200
Postby ShowXpressguy200 » 22 February 2020, 15:14
Never mind after taking a 2nd look this was a newbie mistake....It was just my original scene being offset and copied to make more scenes. Consider this one solved. ;)
ShowXpressguy200
Postby support » 24 February 2020, 09:17
Thank you for the feedback.
Return to Editor - Fixtures
