Chauvet - Freedom Par RGBA (5-Channel)
Postby DJMichaelk » 21 February 2014, 15:07
I'm having the same issue as another user with the quad 5.
I have FreedomPar RGBA's. I want to use the 5 Channel Mode for these fixtures. When I use 4 channel mode, everything works fine in the visualizer. When I use 5 channel, the fixtures are just strobing. I've tried to make a sence to set channel 1 to address 210 (RGBA Mode); no luck. I currently have 16 of these fixtues and will expande by another 20 with a 2nd universe.
Manual
http://www.chauvetlighting.com/products/manuals/FreedomPAR_RGBA_UM_Rev4_ML_WO.pdf
My Current Profile (Stock TXT)
https://www.dropbox.com/s/hd699at1r78p9wv/Freedom%20Par%20RGBA%20%285CH%29.txt
I do a lot of programming using the visualizer (love it). Could you help?
DJMichaelk
Re: Chauvet - Freedom Par RGBA (5-Channel)
Postby support » 24 February 2014, 09:25
Please use this revised attached file, in your lightshow.
Chauvet_Freedom Par RGBA (5CH).txt
(806 Bytes) Downloaded 561 times
Postby DJMichaelk » 26 February 2014, 03:21
Thank You! Works Flawlessly! Looking forward to writing new programs.
DJMichaelk
Users browsing this forum: No registered users and 104 guests
