Chauvet Intimidator 1.0 - master/slave with software?
post here other topics
Postby punkkipper » 26 May 2011, 09:50
I have two chauvet intimidator 1.0s and I want them to run Master-slave while being controlled by my showxpress software. How should this be setup?
thanks
e
punkkipper
Re: Chauvet Intimidator 1.0 - master/slave with software?
Postby tomrbland » 26 May 2011, 17:41
Set both of the fixtures to the same DMX address.
tomrbland
Postby punkkipper » 29 May 2011, 00:55
I did but there's a problem. When I set the fixtures to "sound active" mode through the software they act independently. If I were to just use the fixtures by themselves WITHOUT software and used a DMX cable to link the two lights, the scanners would act as one "unit"---they talk to each other and move accordingly. When I set the fixtures to the same dmx address and then set the lights on sound active mode through the software the lights do NOT talk to each other----they act separately.
any way to fix this?
punkkipper
Postby tomrbland » 29 May 2011, 14:12
Sorry, I have no experience with your fixtures. I can't suggest how to achieve this effect, other than suggesting programming a scene that looks as though it is sound to light.
tomrbland
Return to Other
Users browsing this forum: No registered users and 41 guests
