i have 4 isolution I MOVE 7s lamp 150 HTI when trying to make a light show everything works but when i go to use the dimmer to turn the lamp on (i.e uncover the lamp so it lights up) N.o 1 light comes on and N.o 3 But No. 2/4 turn off on the dimmer side everything is opposite all lights are set up the same so they should do the same apart from addresses they are set 1-8-15-22 as the programme says to set them. These are the values below can you help thanks. these are the values i made as there was not 1 on the programme
ViewType = VIEW_TYPE_HEAD
ViewPower = VIEW_POWER_LAMP250W
ViewAnglePan = 120
ViewAngleTilt = 90
ViewAngleBeam = 16
ViewReversePan = FALSE
ViewReverseTilt = FALSE
ViewReverseDimmer = FALSE
ViewReverseIris = FALSE
ViewColor = 16777215
Channel = pan
Channel = tilt
stop,0,0 left_rotate,10,120 stop,130,130 right_rotate,135,245
Channel = shutter
closed,0,0 strobe,16,131 shaking,132,247 open,255,255
Channel = gobo
Miscellaneous/open,0,0 Yagang/11,16,31 Showtec/explo575-001,32,47 Yagang/10,48,63 Chauvet/tire 1,64,79 Chauvet/144014,80,95 Martin/triangle,96,111 Chauvet/4 dots,112,127 Miscellaneous/rotate,128,255
Channel = color
white,0,0 green,13,25 magenta,26,38 light_blue,39,51 yellow,52,63 orange,64,76 blue,77,89 uv,90,102 light_green,103,115 pink,116,127 rotate,130,255
Channel = gobo_rotate
stop,0,0 left_rotate,10,120 right_rotate,135,245 stop,255,255
Channel = dimmer
website for manual http://www.maxlight.ru/downloads/acme/imove-7s-8s.pdf
light beam opposite [fixed]
Re: light beam opposite
Ive not made a show up yet im just setting up everything ive uploaded this to youtube to show you what is going on please click on link and you will see
http://www.youtube.com/watch?v=0X0UmQWf ... ture=g-upl
thank you
thank you
May be because you have set "Dimmer Inversion" in the fixture's menu (?)
OMG how thick am i done everything did not even think of that thank you so much i can now get on with this and start making programmes thank you again
Brad
Brad
