Version 8.2.10 is ready
Posted: 29 December 2016, 16:15
The software is available here:
viewtopic.php?f=85&t=114All changes are listed here:
viewtopic.php?f=75&t=4344
fix for version 8.2.11
Posted: 31 December 2016, 18:29
Midi outputs initialized at software start.
Midi logger window (
main menu => Windows => Midi logger) to see the midi events in real time (might help for debugging).
viewtopic.php?f=85&t=3438
fix for version 8.2.12
Posted: 04 January 2017, 08:40
Bug in certain circonstances with very reactive midi device (APC Mini) fixed.
fix for version 8.2.13
Posted: 20 January 2017, 16:35
Live - Hidden parameter to switch on "auto BPM" at software start
Live - Midi outputs initialized at software start
Live - red rectangle outline for buttons at "on" state
fix for version 8.2.15
Posted: 30 January 2017, 19:14
Sequential List - function "Move to" changed
minor bugs fixed
Caution: in "Live => Button => Speed properties" all links to the first Speed Master Fader will be lost. You have to manually redo the link for each button where the first Speed Master Fader is used.
You have to make this change in your lightshow only one time.
Afterwards your lightshow will be ok for this fix, and for all further software versions.
