USB connection fails randomly
Postby buensabor » 11 November 2012, 20:08
Do good afternoon, I am writing because I have problems of USB connection, the connection on the Remote box not adjusted properly resulting in a connection failure, I could tell where should I contact? Greetings and thanks
buensabor
Re: USB connection failed
Postby support » 12 November 2012, 07:30
Please contact your retailer for maintenance support.
Postby buensabor » 08 April 2013, 09:17
Follow the problem after replacing cable connection, the connection fails randomly, show me the email of maintenance support?
buensabor
Postby support » 08 April 2013, 09:42
It looks like the usb connector on pcb must be changed.
Two solutions:
- in order to save time, you change it in your side. You can buy the required part here: http://radiospares-fr.rs-online.com/web ... b/6741328/
- you return the interface to your retailer, for maintenance service
Re: USB connection fails randomly
Postby buensabor » 12 April 2013, 18:14
Connector replaced, continuous random error in failing connection.
Where housing costs for repair?
buensabor
Postby support » 12 April 2013, 20:03
Return to Remote
