calender setting on Sweetlight [moved]
Postby 24carrot » 15 January 2012, 20:30
Postby 24carrot » 15 January 2012, 16:51
Can anyone help me, I'm trying to create three different lighting effects throughout the day. morning, afternoon & evening. The light show starts at 8am, then changes to show two at midday and then changes again at 4pm and then finishes at 8pm. This is on a calender setting so it runs 365 days a year. The trouble when the 3 seperate light settings change, they change instantly rather than gradually.as they are on a timer/calender. Is it possible for the shows to gradually change from one to the next rather than changing instantly and abruptly?
24carrot
Re: calender setting on Sweetlight
Postby support » 16 January 2012, 08:20
In computer mode or in stand-alone mode ?
Postby 24carrot » 16 January 2012, 09:41
[quote="support"]In computer mode or in stand-alone mode ? in stand alone-mode
24carrot
Postby support » 16 January 2012, 17:05
In stand-alone mode, fade works inside scenes (from step to step).
But scene switching is in snap mode.
Postby 24carrot » 16 January 2012, 18:18
support wrote:In stand-alone mode, fade works inside scenes (from step to step).
So if i want it to change at 3 set times a day for 365 days how would i do this so it would fade from one to the next at a set time of day
24carrot
Re: calender setting on Sweetlight [moved]
Postby support » 16 January 2012, 19:09
This should be possible if each scene is like this:
- first step is same as last step of previous scene
- second step is wished dmx levels
- add several long steps (copy of step 2), in order the scene does not loop
Postby 24carrot » 17 January 2012, 11:27
I'm new to this and I'm afraid I don't understand what you are describing. Would it be possible for you to explain it to me simply, step by step? Much appreciated :shock:
24carrot
Postby 24carrot » 17 January 2012, 17:32
support wrote:This should be possible if each scene is like this:
24carrot
24carrot
Return to Remote
Users browsing this forum: No registered users and 21 guests
