Vista 64bits driver [fixed]
PostPosted: 06 January 2010, 02:14
by jtorrence
Was there ever any resolution to the USB100 / Vista 64 Bit driver issue using showexpress. The driver install complains about the INF file not having the proper entries. If the driver is available where can it be downloaded ?
Re: Vista 64bits driver
PostPosted: 06 January 2010, 18:48
We just uploaded new usb driver files: viewtopic.php?f=3&t=65
Howerver, we do not guarantee and we do not give support for our products under Vista 64bits, because this operating system is not stable.
PostPosted: 06 January 2010, 20:49
by jtorrence
I got a message saying I needed a digitally signed driver for ftbibus.sys. Do you have that available ?
PostPosted: 06 January 2010, 23:17
Our drivers are not Digitally Signed.
You have to use key F8 (and change an option) at computer boot to disable the Digital Signature control, or to use a patch which does that automatically (you can easily find one with Google).
PostPosted: 07 January 2010, 16:38
by jtorrence
So what exactly is the process to start the driver installation from scratch ? I've unistalled and scan for new hardware, but it is not letting me select the location of the drivers ? Where should the drivers be for automatci location ? should I manually delete all teh driver files from the machine and reboot first ? How do I know if digital signatures are off ?
PostPosted: 07 January 2010, 17:40
PostPosted: 07 January 2010, 19:29
by jtorrence
Works as expexted. Case closed.
