Wired(wireless) problem
dmilasin
Post by dmilasin »
Hi to everyone
I have a strange problem I have not found a solution yet.
Namely, I have a set of four led reflectors and two moving heads all working okay wirelessly or wired connected.
The problem is when I have everything connected wirelessly except one of the reflectors that is connected by cable then scenes that contain channels like strobe, colormacro, pulse and the like does not work if moving heads are involved.
When I turn off moving heads scenes , everything works.
But If all reflector is wireless and one moving head on cable everything works ok.
but if I connect that one reflector by cable and engage the moving heads reflector not working.
Scenes like simple color change works but strobe or color mix etc doesnt work if i have moving head scene, strange is that if all is wireless or all reflector are wireless and one moving head on cable everything works.
I have 5 wireless controler that becouse need on on cable.
See pictures
Thank you if somebody know what is problem
Return to “Cable”
