Driver problem
Driver problem
Postby priza166 » 04 October 2014, 10:18
Hello i downloaded the drivers from the link in FAQ's "all the drivers you need" i did the process to install them and then my pc says "we found the driver but for some reason the installation failed" code10. Please help me as soon as possible
priza166
Re: Driver problem
Postby support » 04 October 2014, 22:12
In order to know if this problem is only with your pc, could you please try with another pc and let us know the result ?
Re: Driver problem
Postby priza166 » 06 October 2014, 18:59
Ok i'll try it on another pc and i will inform you
priza166
Re: Driver problem
Postby tomdavi » 24 October 2014, 17:28
Hi I have the same problem - on checking the drivers and cable it appears I have a v1.06 cable and the driver calls itself 1.05.
The cable works fine on my desktop which runs windows 8
Its very annoying ! Help much appreciated
T
tomdavi
Return to Cable
