Version 6.28
Version 6.28
Postby JohnRichards » 26 September 2011, 16:53
I have just finished shows using Version 6.27Beta with no problems, and now after the show upgraded to V6.28 and noticed that when my Xpress100 cable is plugged in I can only see the 1st 10 Dmx channels in the scene editor, even if I only have 3 fixtures with under 100 dmx addresses. The Live module still works, and if I unplug the cable I can modify all scenes with the scene editor, but this makes live editing a problem. Re-installing my previous version has sorted the problem out in the meantime. Any suggestions or tweaks to fix new version?
JohnRichards
Re: Version 6.28
Postby support » 26 September 2011, 20:53
Re: Version 6.28
Postby JohnRichards » 26 September 2011, 21:11
I am totally aware of the limitations of the Xpress100.
I have been using it for many years now.
My only problem is with the new software (version 6.28).
The problem is not there if I go back to Version 6.27Beta.
JohnRichards
Re: Version 6.28
Postby JohnRichards » 28 September 2011, 09:04
Is someone from support going to answer my question ?
JohnRichards
Re: Version 6.28
Postby support » 28 September 2011, 12:57
This was a beta version.
Re: Version 6.28
Postby JohnRichards » 28 September 2011, 16:56
So is V6.27 as per your website.
Which one is the correct one to use ?
JohnRichards
Re: Version 6.28
Postby JohnRichards » 28 September 2011, 17:00
I also needed to say that the version loaded with the problem is Version 6.281, your lastest release on the web which is not a beta version.
JohnRichards
Re: Version 6.28
Postby JohnRichards » 29 September 2011, 18:01
Let me try again.
Does support register my fault as a problem ?
JohnRichards
Return to Cable
