Instruments Not Staying in Position in 3d
Posted: 07 May 2020, 20:24
Hi Guy's,
Just a quick problem when i moved instruments into position on characters in 3d, like Guitars to the male images then switch off software.
When i start the software again and activate the 3d the positions of the instruments have moved into different areas of the 3d image and are no longer where i put them and sometimes, they disappear altogether.
Just Checked and one of the male characters that i set behind the Drums has completely disappeared too.
Hi support, been quite a while since the last post have you had chance to fix this problem if so is it in the latest update 9.2.19 which I have updated too.
