graphic issues in v9 3dview
Posted: 06 August 2018, 10:59
i'm on windows 8, v9 beta, 64 bit.
this is the problem:
happens with every color
these are my settings:
when i turn gobos off, the problem is gone, (even though these fixtures are rgb pars) and when i check opengl compatibilitymode, the problem is also gone, but i believe that's the old 3dview.
the problem does not occur when using moving heads on open, but when i use a gobo with gobos enabled in the settings, the problem does occur.
