Can we run 3DView on seperate computer ? [fixed]
Postby vwguy » 20 November 2010, 11:06
I use a laptop to run sweetlight. When programing a show I usually connect an external monitor to run the 3D View on. This leads to a lag between running audio and light show in Timeline mode. Is there a way of running the 3D View software on a seperate computer connected to my laptop through a network cable to eliminate this lag?
Many Thanks,
Will.
vwguy
Re: Running 3D View on seperate computer
Postby jaxx00974 » 20 November 2010, 13:43
Are you using Mp3's ?
jaxx00974
Postby vwguy » 20 November 2010, 15:48
Yes I am using MP3s. Does this make a difference?
vwguy
Postby tomrbland » 20 November 2010, 17:00
It is best to use uncompressed audio formats. For some complicated reason that I can't quite remember. Try using a WAV file.
tomrbland
Postby jaxx00974 » 20 November 2010, 18:58
Mp3 all use codecs, the resolution with codecs causes the lag, use WAVS and you will be laughing man,
Cheers,
Lee.
jaxx00974
Postby Niffo » 21 November 2010, 21:17
You can run 3DView on a separate computer (in fact ControlBoard and ScreenControl software are network servers). For that, you have to
- Install the software on both computers
- Install the LightShow on both computers
- Correctly setup the IP addresses in the ControlBoard of the computer who is not connected to the interface
- Correctly configure the firewall(s) if needed
Return to 3DView
Users browsing this forum: No registered users and 34 guests
