martin mac allure needs to be fixed
Postby Gabriel070 » 16 November 2021, 09:56
hi the martin mac allure (68 channel) shows up as 7 different moving heads but linked, on 3D view, (could you fix that). i believe its because the allures have a specific feature that separate the colours and individually show up (7 segments effect) as in this video. https://www.youtube.com/watch?v=iEpDR_jH26g (could also make that effect on the program)
Gabriel070
Re: martin mac allure needs to be fixed
Postby support » 16 November 2021, 18:56
Sorry but 3DView is not able to show a multi-segments beam.
FYI: https://thelightingcontroller.com/viewt ... f=13&t=668
Postby Gabriel070 » 16 November 2021, 19:49
thats ok but did you fix the 7 different fixtures playing as one on 3d view (mac allure 68 channel).
this is what it does.
Gabriel070
Postby SeekLighting » 16 November 2021, 20:21
Gabriel070 wrote:thats ok but did you fix the 7 different fixtures playing as one on 3d view (mac allure 68 channel).
From what I understand, it's supposed to do that. What you can do to get a close recreation of the multi-element fixture is drag all 7 heads together so they sit on top of each other. That's as close as you're going to get I believe.
Postby Gabriel070 » 17 November 2021, 12:06
ok thank you, i put them all together but the only problem is that the clarity of the light fixtures together is very bright
Gabriel070
Postby support » 17 November 2021, 13:57
You can reduce the power of the beam, in the properties of the fixture.
Return to 3DView
