Single fixture showing as 4 [fixed]
alexp_uk
Post by alexp_uk »
I have 4 single moving heads fixtures but in 3D view it is showing 4 heads for each one? Is there anyway to fix this?
Thanks, Alex
Re: Single fixture showing as 4
Please post the personality file (TXT file).
We will check it.
alexp_uk
Post by alexp_uk »
ViewType = VIEW_TYPE_HEAD_WASH
ViewPower = VIEW_POWER_LAMP250W
ViewAnglePan = 540
ViewAngleTilt = 270
ViewAngleBeam = 8
ViewReversePan = FALSE
ViewReverseTilt = FALSE
ViewReverseDimmer = FALSE
ViewReverseIris = FALSE
ViewColor = 16777215
3DViewShape =
2DViewImage =
Channel = pan
Channel = upan
Channel = tilt
Channel = utilt
Channel = pantilt_speed
speed_control,0,225 blackout_moves,226,235 no_function,236,255
Channel = shutter
closed,0,31 open,32,63,notusedinlc strobe,64,95 open,96,127,notusedinlc pulse_strobe,128,159 open,160,191,notusedinlc random_strobe,192,223 open,224,255
Channel = dimmer
Channel = color_macro
no_function,0,7 index,8,255
Channel = color_preset
no_function,0,10 White 2700K,11,20 White 3200K,21,30 White 4300K,31,40 White 5600K,41,50 White 6500K,51,60 White 8000K,61,70 Blue [Group 1] - Red [Groups 2 3 4],71,100 Blue [Group 1] - Green [Groups 2 3 4],101,130 Green [Group 1] - Red [Groups 2 - 3 - 4],131,160 Red [Group 1] - Blue [Groups 2-3-4],161,190 Green [Group 1] - Blue [Groups 2-3-4],191,220 Red [Group 1] - Green [Groups 2-3-4],221,255
Channel = color_macro mode
no_function,0,189 Edit a New White Balance,190,254 Store a New White Balance,255,255
Channel = effect_macro
no_function,0,10 macro_1,11,40 macro_2,41,70 macro_3,71,100 macro_4,101,130 macro_5,131,160 macro_6,161,190 macro_7,191,220 macro_8,221,255
Channel = effect_speed
Channel = red, , 1
Channel = green, , 1
Channel = blue, , 1
Channel = white, , 1
Channel = red, , 2
Channel = green, , 2
Channel = blue, , 2
Channel = white, , 2
Channel = red, , 3
Channel = green, , 3
Channel = blue, , 3
Channel = white, , 3
Channel = red, , 4
Channel = green, , 4
Channel = blue, , 4
Channel = white, , 4
Channel = control
no_function,0,79 reset,80,84 no_function,85,90 Store White Balance Enabled,91,93 no_function,94,99 pattern_01,100,119 pattern_02,120,139 pattern_03,140,159 pattern_04,160,179 pattern_05,180,199 pattern_06,200,219 pattern_07,220,239 audio,240,255
This is because the RGB channels are declared in heads #1 to 4.
In the window "Edit channel", you have to set the parameter "Head number" to "All".
Return to “3DView”
